0 Members and 93 Guests are viewing this topic.
synchro1
Quote from: Spilled Fluids on July 11, 2015, 12:20:21 AM
Perhaps a little over dramatic.
All that was required was to hit the caps lock key :>)
But since you don't seem to have anything constructive to add to the conversation, it's probably best that you take a vacation form overunity.com.
Why cramp his style? This Junior Member supplied the schematic for Tinman's "Mystery Circuit" that TK just successfuly demonstrated, and has offered to repeat the Bifilar magnetic attraction test with a ferrite core. English doesn't appear to be his first language. Perhaps it's just simpler for him. Lay off the Dude! We don't need another casualty.
synchro1
https://www.youtube.com/watch?v=kJcRh_3I3VU
What does Redrichie's reed shorting on a piggyback coil have in common with the Tinman's "Rotary Transformer"? How does the position of the reed switch affect the "Wave Reflection" and tune the common core to achieve Lenz Reversal?
synchro1
Increasing or decreasing the Core VRM, can speed up or slow down the arrival of the reflected pole formation. I envisioned a solenoid coil with an electro-magnet core that was energized by a second covering coil, and regulated by Tunnel and Zener Diodes. This kind of coil can control the core tuning to achieve Lenz Reversal along with the addition of backing magnets.
The speed of magnetisem through a ferrite core is not instantaneous and requires a time interval. This interval can be controlled by regulating the core's VRM.
Just wraping a ferrite coil core a few times and connecting battery electrodes through a variable resistor, then shorting the outer coil should help control Lenz Reversal. This crude approach would requie a separate power source to energize the electro-magnet core of the shorted output coil! A simple testing approach. Once set up it would be possible to vary the strength of the electo-magnetic core with a potentiometer. The outer coil can be connected to a load, and once operating ranges are established, diodes can help the coil regulate the internal loop.
Spilled Fluids
Quote from: synchro1 on July 11, 2015, 08:52:40 AM
There are no excuses for bad manners; even on the Internet. If he/she can't play nicely then good riddance.
minnie
   It's a real shame Seychelles has been put off.
  I don't see anything wrong with virtually anything people write
or with their particular style.
   The trouble with censorship and the like is that it kills everything
off.
   The way I see it is if someone offends or bores you just don't
read their stuff.
   ARE YOU STILL THERE????
                    John.
