synchro1
Will a magnet disrupt the flow of electricity through a nearby wire?
shylo
Hi Tinman glad to see your still here.
I'm testing with the motor right now.
Farmhand if you put a bridge on each field coil ,charge a small cap bank, short one coil dump the caps to the other coil then reverse the operation ,then repeat.
Add a boost circuit, maybe that might be it?
I'm waiting for my boost circuits to arrive.
It does make quite a difference when you feed the stator coils seperately .
artv
gotoluc
Quote from: TinselKoala on July 16, 2015, 09:16:58 AM
But if the build details were somehow leaked out... not by you of course... then someone might be able to use it to "save mankind", pump water in poor African villages for nothing, save starving children whose parents can't afford to irrigate or provide medicines....
IMHO anyone who has a _genuine_ overunity/freeenergy device has a moral obligation to humanity to see that it is released publicly and spread as widely as possible.
Thanks for sharing this truth TK
I believe and have always been working towards this goal and thought that TinMan was also!... so I was surprised to see him going another direction which once again has failed to change the global slave situation.
They have designed the trap well, no?
Luc
synchro1
An attraction motor with an air core power coil could be discharged to send it's pulse straight back to the source battery and release the rotor magent at TDC. This would qualfy as a self runner, right? A matching capacitor would make it resemble an LC tank. A tiny battery could replenish the minimal loss. This concept can reverse and run in repulsion with the same pulse saver circuit. This would only take a few Reed switchs and a couple of diodes. I may be reinventing the "Ossie Motor".
I just realized I already built and tested this motor.
gotoluc
Quote from: tinman on July 16, 2015, 10:02:42 AM
Quote from: verpies on Today at 02:51:57 PM
Could you hypothesize for posterity an answer to the following question:
Would "powers that be" do anything to you if you publicly disclosed all details of your device before they got to you?
TinMan's answer: I have no way of knowing that verpies.
May this be a lesson to all who wish to make a change in the world!... DO NOT FALL FOR THE TRAP!!!
SHARE,  SHARE,  SHARE,  SHARE
This is the way the Universe operates and an example of how we should.
Luc
