0 Members and 57 Guests are viewing this topic.
Just to sharpen the point a bit more:
If there is some outside source of energy being somehow picked up by the device, then the input power measurements are in error, since they aren't measuring and counting that extra input.
There are many ways to test the hypothesis that some outside source of energy is involved. Have any of them been applied to the present problem?  Once all conventional outside energy sources have been tested for and ruled out... then some _new_ energy source must be at work, if CofE is to be saved. What's better, a new previously unknown source of energy that can be extracted by a vacuum cleaner motor and some other bits and pieces -- or a violation of CofE?
nelsonrochaa
Quote from: TinselKoala on July 17, 2015, 07:37:43 PM
For example, there could be another battery hidden in the switchbox. There could be some fortuitous pickup of radiated power from a very nearby commercial radio transmitter. Or any of several other things I can think of. We are assuming, I suppose, that the battery or PSU is the _only_ source of power to TinMan's device.
Lol, this is joke or you are talk convictus ?
MarkE
Quote from: Void on July 17, 2015, 03:59:34 PM
Hi synchro1. I guess it is possible that something like electron avalanche in sparks around brush contacts is
freeing up electrons in the air around the sparking contact points. If those free electrons can then be collected by the
contacts and accelerated through the winding wires by the changing magnetic field, maybe there could
be some sort of electrical gain, but that is a lot of maybe's and if's. :) You would need to set up some sort of tests
that demonstrates the concept. Motors with brushes do not typically display COP > 1, so it seems there would have to
be more to it than just sparking brush contacts going on, if sparking really is a factor at all.
All the best...
I know of no evidence that supports the idea that any of those phenomenon add rather than dissipate energy.
MarkE
Quote from: synchro1 on July 17, 2015, 03:43:47 PM
Extra power can enter a circuit through the "Spark".
As evidenced when and where?
maxc
Quote from: Spilled Fluids on July 17, 2015, 03:51:39 PM
A spark is nothing more than an electrical discharge. It cannot and does not add energy to anything. In fact through heat loss it actually takes away energy.
Transmutation Fusion?
