0 Members and 201 Guests are viewing this topic.
tinman
Quote from: Spilled Fluids on July 19, 2015, 03:21:01 AM
Are you now saying that this is a Perpetual Motion machine; it sure looks like it!
It would seem that you are afraid of what I might discover! That is most definitely enough incentive to spend the time no matter what the outcome  8)
BTW; they are not my laws, they are the laws of physics and how things work in this universe.
QuoteAre you now saying that this is a Perpetual Motion machine; it sure looks like it!
Oh here we go again ::)
QuoteIt would seem that you are afraid of what I might discover! That is most definitely enough incentive to spend the time no matter what the outcome  8)
I have little concern as to what you might discover,as you lack the ability to build such a device as pictured,and the ability to fill in the blank's. It was more for the researchers like Luc,jimboot,etc who know about this sort of setup.
You simply cannot look at those diagrams and fill in the blank's,or even understand as to what happens through each complete cycle of the depicted setup-->it is not for you.
You would be more like MH,and need a full description of everything depicted. You would want coil resistances,coil numbers placed next to each coil. You would want to know how each switch is operated,and even what the switches are.then the questions of what kind of core material the cores are made from,what is there inductance value-coil/core. What voltage is the correct value for such a setup-->the list go's on.
This is where guys like myself,Luc,jimboot differ from you. We can fill in the blanks through our own experimentation. Luc managed to find the correct voltage value in a set capacitance value to get his setup to work as efficient as it could. Do you think he calculated that by way of inductance values and the likes?-->i bet he found the correct values by way of experimental outcomes.
So no-this is not for you,as you are one of those that need spoon feeding,one who is just trawling for a device that requires no work on your behalf. So it would be better for you if you just sit back,and wait for the silver spoon to hit your mouth.
Spilled Fluids
Quote from: gotoluc on July 19, 2015, 03:50:54 AM
Okay,so you were doing experiments about 2 years ago but only registered in May of 2015 and never posted before that but you wrote:
That seems to imply that you posted your experiments that failed, no?
My posts were and are at R-G. Since I was not registered here until May, there is no way I could have posted here.
QuoteCan you at least point us to the post where you "I asked for explanations of why my thinking was wrong and learned a lot from the thoughtful answers I received"
Luc
Discus is a bit of a nightmare to find things on but if you like you can ask Mark E, Mark D, Simon Derricut, or many of the other regulars over there about my experiments and their inputs.
tinman
Quote from: Spilled Fluids on July 19, 2015, 03:56:53 AM
And this forum -RG?
What is it's entire name,as RG leaves a lot of ground to cover.
Regular Guru's
Reluctant Gnoms
Retarded Grandpah's
gotoluc
Quote from: tinman on July 19, 2015, 03:59:29 AM
And this forum -RG?
Could it be Russ RWG Research?
@SF what was your user name there?
Luc
tinman
Quote from: gotoluc on July 19, 2015, 04:03:02 AM
Could it be Russ RWG?
Luc
I couldnt see the likes of MarkE being a member of Russ's forum?.
