0 Members and 62 Guests are viewing this topic.
MarkE
Quote from: hoptoad on July 19, 2015, 05:25:50 AM
Since you are so insistent, you best go the site I linked to and get them to change their definition so that RATIO is the paramount point of their definition. In all this you have lost site of the fact that you are verifying that voltage is intrinsic to the measurement of electrical energy.
If voltage is the ratio of energy to charge, then energy is also a ratio of voltage to charge. Charge being the only factor which is non variable.
The point I've been making is simple. You claim there is no energy IN voltage. Yet your maths ratio shows an explicit relationship between the two. Then to top it off, an independent source that I cite makes no mention of, nor highlights ratio, it just references Potential Energy measured for an arbitrary unit. All measurements are based upon arbitrary units. So what ?
LOL, semantic games and strawmen.  I have claimed and insist that voltage is the ratio of energy to charge.  Voltage is not energy.  No value of voltage gives us any quantity of energy until associated with a defined quantity of charge.  If you want to claim that I have said anything different, you are welcome to comb through my posts and attempt to find a supporting quote.
MarkE
Quote from: Spilled Fluids on July 19, 2015, 05:47:30 AM
A lifted rock, once dropped cannot lift itself back up and a compressed spring, once released cannot compress itself. Same should apply to permanent magnets.
As far as we know that is true.  There are many who think they can find a way to get around that "sticky spot" and come up with a closed cycle magnet machine that nets out useful work each complete cycle.  PESN is full of such things.  None of them have ever worked.
hoptoad
Quote from: MarkE on July 19, 2015, 05:47:54 AM
You claimed that there is no energy IN voltage. Other sources say otherwise. On this occasion I will trust the other source.
Spilled Fluids
Quote from: hoptoad on July 19, 2015, 05:58:01 AM
I don't see where Mark is saying there is no energy IN voltage only that voltage does not equal energy. There is a difference.
Tito L. Oracion
Quote from: Spilled Fluids on July 19, 2015, 06:02:24 AM
Actually, adding a small caps in a very high voltage can kill.
you try holding it.  :D   ;D
