0 Members and 60 Guests are viewing this topic.
Quote from: John.K1 on January 28, 2015, 05:32:05 PM
Magnetismus has nothing to do with the bucket coils? ;) Maybe I forgot to insult someone in my comment to be a part of this thread ;)
Fair enough , here is the last video of Acula , showing something what I believe belongs here.
http://youtu.be/pYjREkw1v-A
He is showing 2x60W  and he is gonna make it self-runner. His next design will be on iron core.
Good luck trying to get anything Akula presents as a "self runner" actually to work. Nobody else has ever done so, and I personally believe that all his "ou" effects are fakes in one way or another. He's fishing for a Big Fish... so don't be chum.
A new clip from Itsu trying out a new configuration suggested by Chris:
https://www.youtube.com/watch?v=xr_4EgpBE7g&feature=youtu.be
This one is "fighting EMFs from two bucking coils creating a short circuit in parallel with a load resistor."  We are really pulling out all the stops.
It's related to the attached scope capture compliments of Itsu and his comments below plucked from OUR:
QuoteAn alternative method to check if my coils are in bucking mode or not was presented by MileHigh on my youtube channel
He proposed to probe the both partner coils with 2 probes with the ground leads at the center point.
He states:   "The outputs should be in phase for bucking mode and 180 degrees out of phase for normal mode."
See here the screenshot of this setup which shows both signals in phase, meaning in bucking mode.
QuoteGood luck trying to get anything Akula presents as a "self runner" actually to work. Nobody else has ever done so, and I personally believe that all his "ou" effects are fakes in one way or another. He's fishing for a Big Fish... so don't be chum.
Recently somewhere around here I mentioned my "attention wanker" theory.  It could be an almost or literal sexual thrill for Akula in the USSR to get the Westies to jump though hoops for him.
John.K1
Quote from: TinselKoala on January 28, 2015, 05:37:52 PM
How could you be doing anything "wrong" when it is so unclear just what "right" might be?
:o
Your aircore coil set in the back could be run as a resonator for a solid-state Tesla coil. With the right drive frequency and coupling between the primary and the secondary you can get VRSWR: voltage rise by standing wave resonance, which will indeed produce interesting effects at the top of the coil.  It's easy to light up neons and fluorescents with the output, even with just ordinary drive straight from the FG to the primary. With a bit more circuitry you can make the primary drive "autotune" to the resonant frequency of the secondary, and feed the primary with higher current ... then you will _really_ see some interesting effects from the secondary.
That's what I have said before, it is like two Tesla coils connected et the tops and bottoms.
Quote from: MileHigh on January 28, 2015, 05:25:32 PM
Conrad, TK:
The issue that I have with the low-side MOSFET switch is that I don't believe that it is the right type of excitation as called for in Chris' documents.  The MOSFET alternates between a low impedance drive signal and then a high impedance disconnect.  I believe the "correct" drive signal would come from a continuously connected sine wave voltage source like from an audio amplifier.
I think a handy drive signal source would be a cheap car audio amplifier.  It runs off of 12 volts and has a differential pair output.  I believe that they are basically giant operational amplifiers.  If you get a really powerful car audio amp then it's current sourcing and current sinking capabilities must be quite high.  In other words it's a "stiff" variable voltage source, to use MarkE's terminology.
More on this topic of "correct" drive: The driver circuit EMJ uses for Exp1 and 2 in the pdf is a high-side switch using mosfets, with a unipolar output pulse. The other circuits he has recommended, like an H-bridge, will also give an approximately squarewave bipolar pulse to the coils.
See below screenshot from one of his videos (bottom trace is drive from his H-bridge, I believe):
