0 Members and 45 Guests are viewing this topic.
EMJunkie
Quote from: TinselKoala on September 21, 2015, 05:23:14 PM
Everyone failed? I laugh at you. YOU failed, and that's the real truth.
You made some bogus measurements on that circuit and claimed OU.
But I made some _actual_ and proper measurements and showed that it wasn't OU at all, even though it can light up a bunch of neons.
Remember?
Again, I gave no measurements on that Circuit, I gave that circuit to get the ball rolling, and roll it did not!
You failed to explain how that circuit was, and still is the best Neon Circuit you have ever built! You still fail to understand what the actual goal is there! Induction
If you decide to aim a little higher than failure then you must understand what is presented to you!
   Chris Sykes
       hyiq.org
shylo
Are you trying to bounce it back and forth?
The ossilations will balance out, it always seems to find libreium.
artv
EMJunkie
Quote from: shylo on September 21, 2015, 06:19:23 PM
artv
@Shylo - No, its Induction!!!
See: http://www.overunityresearch.com/index.php?topic=2760.msg45207#msg45207
For Everyone: Asymmetric Fields! Next to no Pushing, but at the same time opposition, allowing a force to Attract another Force. An addition to Newtons Third Law! How could this possibly work? Does a Magnetic Field extend past the Repulsive Force of another? Where is it that interaction of Fields are Really Occurring?
Quote from: EMJunkie on September 15, 2015, 07:52:04 PM
Bump!!!
For those that do not comprehend, have not been following, but wish to comprehend and follow, to learn something and to achieve a common Goal:
Action: - (Primary Coil) - Your Input. A Magnetic Field, a result of Current Flow in your Primary Coil, that will likely have a Reactive Component. Considered as the Prime Mover.
Reaction: - (Secondary Coil) - Typically considered as a Negative result on the Action. Lenz's Law (the -), a negative result of the Secondary Coil on the Primary Coil.
Counter-Reaction: - (Secondary Coil) - Another Negative result, but this time assisting the Action, the primary, or the Action, but at the same time Countering the Reaction. Lenz's Law (the -).
The two Secondary's are what I call Partnered Output Coils!
These principals can be arranged in many configurations that may result in a working device, and the opposite is also true.
   Chris Sykes
       hyiq.org
   Chris Sykes
       hyiq.org
tinman
Quote from: EMJunkie on September 21, 2015, 04:41:30 PM
Fair Comment Tinman, Understand and respect where you are coming from.
The way I see it, we just have to fight the good fight, if anyone has an idea, they should not be Stomped Down, if someone has an experiment they should not be Stomped Down, if someone can repetitively achieve something that others can not then they should not be Stomped Down!!!
It is up to you what you do with your knowledge and device Tinman, but we surely have a responsibility! A responsibility to share the gifts we have been given? We really do not have much time left at all now!
   Chris Sykes
       hyiq.org
QuoteIf you were to give us a one liner, why you stopped posting Data on your Rotary Transformer , what would that be?
An applied force,over a given time,on a moving mass,can change the destination of that moving mass.
QuoteI have a fair idea, its because of the attitude and Dogma here? Something akin to a plastic Bag, glued over everyone's head?
No-not so much.
What you will find is many that have been conditioned to accept what they have been told.
E.G-Most think that an !off the shelf! generator(say 3kva)is under 100% efficient,when in fact a standard !off the shelf !generator is over 100% efficient when all output energies are taken into account. People just choose to believe what they are told,and accept the wide spread rumor that!lets say! 35% of the fuels energy is transformed into mechanical energy,while the remaining 65% of the fuels energy is transformed into heat energy. The fact is,drawing mechanical energy from an ICE dose not decrease the heat energy from a given amount of fuel-the heat energy output from a given amount of fuel remains the same regardless of whether or not mechanical energy is being drawn from that ICE.
It comes down to what you choose to believe from word of mouth,and what you choose to be proven wrong through experiments of your own.
