0 Members and 103 Guests are viewing this topic.
poynt99
Quote from: Magluvin on September 30, 2015, 11:23:33 PM
Not really. If the primary flux, well below saturation, is always encapsulated in the core, how does primary flux affect the secondary winding?? Where the 'Faraday' are you coming from? ;D
Mags
If an alternating (or varying) current through the primary produces flux through the core, could perhaps this flux through the secondary (via the toroid core) produce an alternating current (or at least an emf) through the secondary?
gyulasun
Quote from: gotoluc on September 30, 2015, 05:21:48 PM
ADDED: I just noticed the difference between 3b and 5b where the secondary load resistor is dissipating more power on 5b and at a reduction of input power compared to 3b which has no diode on the primary input coil. So would that not mean there would be a benefit on adding a diode across the primary coil when pulsed with DC?
Luc
Yes it would mean that, you got 317mV (rms) voltage across the 1 Ohm instead of the 237mV (rms) while at the same time the voltage dropped a little from 54.5mV rms to 49.7mV rms across the 0.1 Ohm CSR at the input side, indicating a little reduction in input power.
Thanks for doing and showing these tests.
Gyula
Jeg
Hi guys
The video below shows what Tinman describes, and a little more. ;)
https://www.youtube.com/watch?v=NvgajlfX0yI
EMJunkie
Quote from: Jeg on October 01, 2015, 03:14:26 PM
Hi guys
@Jeg - Nice Video! Thumbs up from me!
@GotoLuc - No Problem, happy to share what I can!
   Chris Sykes
       hyiq.org
EMJunkie
Our current discussion is fantastic!
I think its important to point out, in standard Transformer Theory, Transformers are engineered such, that there is always the absolute minimum Flux Leakage! Always! High Core Permeability and Peak Magnetic Fields that will always be well below the point of saturation and so on...
Flux Leakage is considered a Loss!
However, Flux Leakage can bring about Flux Cutting, and some would say a Motional Magnetic Field. At least Motional from the Source that was the Primary.
A Motional Magnetic Field creates an extra Electric Field, not normally seen!!! This is v X B
Effectively this is supercharging the space around the Coils.
   Chris Sykes
       hyiq.org
