EMJunkie
Quite sometime back, I built a small device. The Inventor called it the "Ward Force Generator" - Invented by Steve Ward.
Quite an in-genius device and also very simple!
A Magnetic Rotor is placed in a Stator that is configured such that a small Air Gap is all that stops the Stator being a Closed Loop Magnetic Circuit. As the Rotor Spins up and the Stator Coil (Output Coil) creates a Magnetic Field ((- of the Source) Lenz's Law), the Magnetic Flux jumps the Air Gap, it is bent around in such a fashion, that the Rotor, with a Permanent Magnet on it would float on the Bent Field, thus Speeding the Rotor up.
The easiest way to build this is from the common, "Magnetic Base Dial Indicator"
I thought it would be interesting to share, many here may already have built or studied this device.
   Chris Sykes
       hyiq.org
P.S: This device was not new, again its a rediscovery of a device over 100 years old: Simple Dynamo - See: Old Dynamo from a 1903 Book
MagnaProp
Quote from: gotoluc on October 01, 2015, 09:31:06 AM
Yes, like a flyback diode except the diode is connected across the coil which feeds back the flyback and seems to hold the magnetic field longer then the input pulse.
See below scope shots of no diode vs with diode.
Luc
Looks good thanks. This was the info I found on flyback diode that made me think of your experiment. As the flyback is captured it's sent through the coil again in the same direction the electricity was initially flowing in so it kills it's self while keeping the initial field there longer. Brilliant.
This was the flyback info I found. Posting it for my own reference as I'm not as knowledgeable about this stuff as most here are.  (http://www.douglaskrantz.com/Flyback_Diode.html)
tinman
Quote from: MileHigh on October 01, 2015, 09:48:43 AM
As a follow-up to my previous posting, probably something like 99.5% or more of the flux produced by the primary will cut the secondary of the coil.
Thank you MH.
So given that 99.5% of the available (produced by the primary)flux is going to cut the secondary windings,and the secondary windings are not contained within the core,then how is it that some here can say that most of the magnetic flux produced by the primary coil !is! contained within the core???.
tinman
Quote from: Jeg on October 01, 2015, 03:14:26 PM
Hi guys
The video below shows what Tinman describes, and a little more. ;)
https://www.youtube.com/watch?v=NvgajlfX0yI
Great video Jeg
Could you go one further and place a load on the coil you used as the secondary in the last part of your video in stead of a dead short across the coil-say a 100 watt incandescent bulb-just so as we can see some useful work being done by the secondary coil,and that it is still attracted to the primary,and not repelled as the laws that be say it should be.
Cheers.
EMJunkie
Quote from: tinman on October 01, 2015, 06:37:13 PM
Thank you MH.
This is something that requires an Experiment:
Take a standard Transformer, E I, or a Toroidal whatever, doesn't matter.
Run up the input, from Mains or Audio Amp, doesn't matter.
Load the secondary...
Use a good Magnetic Detector, Compass, or decent Hall Probe, what ever, but not the rubbish ones...
You will find:
when alternating current is surging through a transformer an electric field surrounds it
Not a Magnetic Field, not unless the Transformer is Saturated. Not in a Conventional Transformer anyway. Make a Gap in the E I Core then you can detect all the Magnetic Field you want...
   Chris Sykes
       hyiq.org
