0 Members and 199 Guests are viewing this topic.
Magluvin
Had to put off the little project for a few days. Trying to make some time tonight to set up.
Had broken one of the halls from the pc board I had shown earlier. The second one came out fine. Put the hall and core in some acetone for a couple days and still didnt come out. While going through parts boxes I found a small package of linear halls I bought a couple years ago. Thought I had lost them. Then I got an idea to not break the hall from the core of the current sense circuit from the board and try using it as a unit in the hole of the wound core. It fits without touching the larger core or the windings. The hall core is cut so the hall faces the cut core ends where the thick current sense wires produce field in the core to be measured. So Im thinking it might be another tool to see if mag field crosses the hole of the wound core. So Ill try that and the bare hall to see what happens.
Took in a job to assemble a lotus esprit that it seems nobody wants to tackle. So had a few days of talking with the cust and going over what we have and dont have. Will post some pics as the project comes together.
Mags
MagnaProp
poynt99
Quote from: Magluvin on October 13, 2015, 05:26:44 PM
Why not use the linear hall sensors?
You don't want anything that could be induced by an E field. Could you post a pic of this core/Hall sense device?
Magluvin
Quote from: poynt99 on October 13, 2015, 06:42:34 PM
Was just about to do so. ;)
The 1st pic shows the cores with halls, the whole one, the one with 2 broken leads and a piece of the 1st one I had broken the core to remove the hall a while back. Guess I tried to use solvent before and it didnt work. Also a new linear hall shown.
The broken core shows no continuity with the meter. And it is not a full loop with the gap for the hall. So you think the E field would still cause issue with that?  The reason I came up with the idea was the fact that since the fields build densely in the core, so what is traversing across the hole of the core may be not so dense, possibly ever. Anyway, just in case the linear hall doesnt pick up the field, that maybe the one in the tiny core may.  Gunna try
Got the chassis and some of the parts for the lotus in. More pars and the body coming tomorrow.
Runnin out of space and its drivin me nuts. :o
Mags
verpies
I do not know what the adhesive is but if it is based on phenolic epoxy resin then acetone is not a good solvent to use.
I recommend benzene or methylbenzene (toluene), instead,
