0 Members and 114 Guests are viewing this topic.
EMJunkie
Some more Re-Capping:
Lenz's Law is USED and REDIRECTED Back in on itself with a second Coil (Partnered Output Coils):
Quote from: EMJunkie on September 15, 2015, 07:52:04 PM
Bump!!!
For those that do not comprehend, have not been following, but wish to comprehend and follow, to learn something and to achieve a common Goal:
Action: - (Primary Coil) - Your Input. A Magnetic Field, a result of Current Flow in your Primary Coil, that will likely have a Reactive Component. Considered as the Prime Mover.
Reaction: - (Secondary Coil) - Typically considered as a Negative result on the Action. Lenz's Law (the -), a negative result of the Secondary Coil on the Primary Coil.
Counter-Reaction: - (Secondary Coil) - Another Negative result, but this time assisting the Action, the primary, or the Action, but at the same time Countering the Reaction. Lenz's Law (the -).
The two Secondary's are what I call Partnered Output Coils!
These principals can be arranged in many configurations that may result in a working device, and the opposite is also true.
Quote from: EMJunkie on September 25, 2015, 12:16:54 AM
Back to old equations we spoke about some time back: 1 + -1 = 0 then 1 + -1 + 1 = 1...
From the recent Video, this Math shows a new way to look at the same equation:
F12 + -F21 + F31-2 = 1 + -1 + 1 = 1
Action = F12
Reaction = -F21
Counter-Reaction = F31-2
I hope this helps!
   Chris Sykes
       hyiq.org
EMJunkie
Quote from: EMJunkie on January 18, 2015, 03:34:48 PM
@ALL
Reading the prior posts to this thread, we now know How Charge is Separated, Where we have Magnetic Fields; E.G; Primary, Secondary, and that the Secondary is in the opposing direction to the Primary!
We know that the Secondary Magnetic Field is only a Result of Drawing Current from the Charge Separation that we have already bought about from the Primary Magnetic Field Changing in Time!
So, its now fair to say that:
Any Magnetic Field Changing in Time Can Separate Charge
So a Secondary Magnetic Field (Lenz's Law) can be used to actually Separate More Charge Carriers!!!
Quote from: EMJunkie on April 22, 2015, 06:23:07 PM
@TK and all following,
I am going to try to do something nice, I am going to ask nicely, try to be pleasant and to the point...
    1: Induction in a singular coil, where another coil is the prime mover, induces a Current in the opposing Direction to the Prime Mover.
        This is seen mathematically as: emf = -dPhi/dt = Lenzs Law
    2: A second Output Coil introduced, Induction in this second Coil is also the same:
    3: Output Coils A and B are each 1 Volt emf. The direction or turns is such that there is an addition of Electric Field and Magnetic Fields (-)(Lenz's Law) Oppose.
        This is seen mathematically as: emf = 2-dPhi/dt = 1. This is 3 orders of Magnitude larger than Induction Singularly. -1, -1, 0, 1...
There is no negative sign here, A different type of Induction to our standard Induction with a (-) sign. Normally the Wire Impedance would inhibit Current Flow, even though we might have 300 turns or AWG 20 wire, the Current is not Inhibited because the Impedance is lowered by the Coil Configuration. Please think about this. Is this new? No its not! I am not the discoverer! I have merely re-discovered these principals and I am trying to share this. Its Old Technology! The problem is that too many have turned a blind eye, brushed it off as rubbish and not even experimented or thought about this in any detail.
Soon we will have to look at these things. Or the dark ages will ensue again.
   Chris Sykes
       hyiq.org
EMJunkie
Some may say, what does this mean? What's the Math for? Let me explain.
Today we see the Electrical "Generator" as a One for One device. Meaning, what we put in, in Mechanical Energy, we get out in Electrical Energy: 1 + -1 = 0
This example is ideally, there will always be Friction, Windage and  few other losses... In saying this, the best Electrical Generator known today is approximately 99% Efficient.
With Partnered Output Coils, things change: 1 + -1 + 1 = 1
This means, we have a 1 to 1 loss, but we also, because of the Second Output Coil, have a gain of 1. So mathematically, we see: 1 + -1 + 1 = 1
Lenz's Law is a Changing Magnetic Field in Time, perfectly capable of invoking Induction again in a Third Coil. Use it, make this Magnetic Field do some work, don't waste it!!!
   Chris Sykes
       hyiq.org
EMJunkie
Quote from: EMJunkie on December 09, 2015, 09:04:38 PM
To explain a bit more:
In a standard Transformer, we see anywhere from around 80% to 99% Efficiency (99% on the really high tech expensive ones)
Losses include Eddy Current/Hysteresis and so on.
Without taking the losses into account, we have a One to One power transformation ratio. What you put in is what you get out: 1 = 1
With Partnered Output Coils, this changes, because we are invoking Induction, Faradays Law of Induction, we get more than this out: 1 + 1 = 2 (As an example)
So because of standard, already well known, Faradays Law of Induction principals, we see a Gain! This Feed Back Loop does exactly this:
Electromagnetic in nature, responding to a polarizing force, also magnetic in nature, produce, by moving fundamental charges in a conductor, the moving charges polarizing effects that align the quanta energies into a coherent state. Once in this state, the moving charges initiating steady states of the electromagnetic field are opposed by opposing forces equal in magnitude and opposite in direction and a property of the space field. Thus, the moving charges on the electrons that excited the space field into being surrounding the electromagnet are not moving as a source of current flow, but lock the quanta in a coherent state of potential magnetic energy whose effects are evident and energy is there to be converted by unique hardware
   Chris Sykes
       hyiq.org
EMJunkie
Because people are starting to understand these principals, we see more and more demonstrations of Over-Unity:
Partnered Output Coils: Anti-Lenz effect - from: Юрий Лиховид (Yuri Likhovid)
   Chris Sykes
       hyiq.org
