0 Members and 51 Guests are viewing this topic.
picowatt
Quote from: tinman on April 29, 2016, 07:50:10 AM
The point is very simple.
To define what the magnetic force is. Once we know this,then the door is open to a new world.
As i said,to many are only interested in how they can use the magnetic field,and very few are on a quest to define what it is.
We start by finding what can produce the same effect against paramagnetic and diamagnetic Atom's as the magnetic field dose-perhaps a charge of sort's?.
Quote from EMJ-So Diamegnetic Objects have spin in the other direction, Spin Down, this is the High Energy State.
If we take the diagram on the left,and we use a 3 dimensional flip,we see that the two are exactly the same-there is no spin up or down,but one in the same.
Brad
Tinman,
I do not know what EMJ said, but you are correct, both electron's are identical, it is just the "spin up" or "spin down" orientation that is depicted as being different.
Keep in mind that "spin", as well as the depiction of an electron as a "spherical ball" are just tools to assist in helping one understand a given point.  There is way more to it than that...
PW
EMJunkie
Seems we are back full circle? The original Video I posted explains the same thing:
Quote from: EMJunkie on April 28, 2016, 07:01:41 AM
Have been pondering on that.
Only Thing I can think of is Spin Up/Spin Down.
Electron Spin - Diamagnetic vs Paramagnetic & Ferromagnetic Stuff but I am not sure this is what you were talking about?
    Chris Sykes
        hyiq.org
EMJunkie
Regarding the Post of Reiyuki's:
Quote from: Reiyuki on April 26, 2016, 04:59:04 AM
This might help (see attached):
http://www.free-energy-info.com/VladimirUtkin.pdf
Page 6
Does lenz law apply to displacement current?
And the Image that was attached, below:
I believe there is enough evidence to say that Don Smith's work is very similar to the work of Tariel Kapanadze.
    Chris Sykes
        hyiq.org
EMJunkie
In the Video: Don Smith 2006 Tesla Tech
Don Smith said:
Quote from: Don Smith
Don Smith 2006 Tesla Tech (17:42)
Ok this is, ah, something which I have a patent on, it relates to getting a huge amount of energy out when you put a few milliamps of energy in, you end up with like a hundred kilowatts of Energy out.
That won't make sense for someone who thinks of an electrical system, you have to think in terms of Magnetic Flux, because, if you're using electrical flux, everything is dying a heat death and you lose the energy almost immediately, in electrical flux, but in magnetic Flux you can make as many copies of the original as you want, without depleting the original at all, so if you're chasing electrical flux, you're chasing the wrong rabbit, you need to be chasing magnetic flux.
Some years back I did study Don Smith, with a refresher, just recently, he is exactly right 100% - A detailed study on Don Smith will be worth your time if you are interested in this field. hahahaha also the same 1:5 Ratio...
He told you exactly what I am telling you now.
    Chris Sykes
        hyiq.org
Pirate88179
With a little searching, I found the real identity of these folks.  I knew I had seen them somewhere before.....
