0 Members and 180 Guests are viewing this topic.
seychelles
ALL THESE BULLSHIT NEVER WORK AND WILL NEVER WORK BECAUSE IF THEY DID WE WILL BE NOT WASTING TIME TALKING ABOUT IT BUT SEEING IT IN OUR DAILY LIVES BEING USED..
EMJunkie
Quote from: Utopia Now on May 02, 2016, 02:03:40 AM
In this device from Donald L. Smith  you can also  see ( if you look carefully at the pictures ) that the coils are wound opposite .... CW CCW
Here a video in which he talks about this device with a rotating disc between the coils.  Don Smith 2005 Part 1
Here Don again talks about this device ( output 8 x 50 kW ) Don Smith 2006 Tesla Tech at 16 minute 52 sec
Here is told he sprayed magnetorestrictive material on the disc.  Don Smith Tesla tech at 49 minutes[/size]
Hey Utopia Now,
Don talks about something similar to what I have. Don says CW CCW for amps, the other way for Voltage. I also said similar:
Quote from: Chris Sykes Page 11, Guidelines to bucking Coils
Ideally, these devices work with a Step Up configuration. 1:3 is a common Ratio. That's one turn on the input to 3 turns on the output. Current, as you may think, is not stepped down as a result of the Voltage being stepped up.
Don also talks about an Earth, I too have also found an Earth can sometimes be usefull.
I posted the below schematic many pages back:
    Chris Sykes
        hyiq.org
Utopia Now
Don video`s  Center Tap Earth Gounding ... Volts and Amps.
http://www.tuks.nl/pdf/Reference_Material/Donald_L_Smith/don_smith_res_elec_pwr_guide.pdf
The : "Useful Circuits from Nikola Tesla" picture from Donald  Smith pdf shows  Center Tap and plus and minus symbols (which he probably put there with a reason) and the CCW CW  configuration .
Don speaks about Amperage and Center Tap here https://www.youtube.com/watch?v=Cr07kI7HhzU#t=3385
"Center tap important  to getting Amperage"
And thanks to you Chris I watched this video again ... and  every time again I hear or see new things.
He says ( at 58 min. 35 sec. ) bottom half of the coil produces  Amps and top part of the coil produces Voltage.
Here Don shows again CCW and CW combined winding like the drawings from Tesla he showed earlier.  https://www.youtube.com/watch?v=Cr07kI7HhzU#t=8471
And more about Center Tap and Voltage or Amperage way of coil winding from Don.
https://www.youtube.com/watch?v=J77DMZExsSA#t=387
https://www.youtube.com/watch?v=gbX7B_ELFbo#t=497
https://www.youtube.com/watch?v=Cr07kI7HhzU#t=2644
https://www.youtube.com/watch?v=Cr07kI7HhzU#t=2560
https://www.youtube.com/watch?v=Cr07kI7HhzU#t=1300
Anyway I am here to learn   .. I am realy enthousiast  about your work ( website and pdf and video`s ) Chris .
For me it is like a wonderful puzzle ... I have the feeling I understand more and more every day now .
EMJunkie
This is a thing of Beauty!!!
For those wondering, the small box at the top, its a: BERTONEE NPS-12D8S Transformer
Don said this was self sustaining, in one video, there was a 12V 7AH Battery powering this deivice. He also said that this was only part of the complete device.
Beauty, simplicity, amazing!
    Chris Sykes
        hyiq.org
EMJunkie
Before anyone runs out and replicates this device, there is something Don did avoid when questioned on it.
See attached Image, there is not only Three Coils, there may be Five Coils. It maybe the case, there is Four Coils, and this one we see clearly in the below picture, is in fact centertapped to the middle of the other two Output coils.
See on the output, there is a smaller wire attached to the output. I believe the Image above, shows the other one on the other side.
    Chris Sykes
        hyiq.org
