0 Members and 194 Guests are viewing this topic.
darediamond
Quote from: EMJunkie on July 09, 2016, 05:57:52 PM
I understand Darediamond, building is key to getting somewhere, and you will.
Again please stick to the key concepts, they are key concepts for a very good reason. This will maximise your learned knowledge and minimise your learning curve and also save you alot of time and expense!
Keep it as simple as you can! Follow the basic ideas I have already shared.
In all the devices I show, I use vaery small current, 0.5 to 1 amp - I strongly recommend not going any higher than this!
All my main Op frequencys have been around 40 to 5KHz - I strongly do not recommend going higher freq than this!!!
Again do not over complicate something that does not need to be over complicated - You will never reach the end goal other wise.
Start at the Start!!!
   Chris Sykes
       hyiq.org
P.S: Wistiti's first device was 0.031 Amps as an example of what I am saying. AWG 32 Wire would be ok with this current, save a ton of room on the Former, and not waste a ton of Money on Wire (AWG 18 or what ever) that is unnessary!
Chris even if AWG#14 which is upward of 2mm thick is used to make the  primaries, at High Frequency and Proper Match Voltage Application to the ohmic value of the length of the thick gauge coil, low current  would still be drawn.
But the radiation of high frequency is what people do fear and that can be ruled out by placing your high frequency Motionless MoGen(Motor Generator) after completion into Alluminium Box.
God as given humans pen and eraser. All the Solids are in the ground under our feet.
The Electricity which alternators draw from the air operates at High Frequency so for us to make it work for us, we must primarily dine with High frequency.
When you negate lenz in a system and drive the gen at 60hz and u obtained 200w at the secondary while your input is just 20W, at Higher frequency your input will become lower while your output will become higher because your getting friendlier with the Radiant Electrons which your secondary is attracting and Pumping out for you as output.
The Gauge of the secondary under low or high frequency do as well affect the output intensity as to Current especially.
As for the input, I as well do want it to be extremely low which the output is Extremely high.
And the only way to achieve that is by using high frequency and high frequency Core after Enhancing (using serially connected multifillar spirally wound wire)  and winding the coils primaries and secondary in the proper directions.
EMJunkie
Quote from: darediamond on July 10, 2016, 02:29:45 AM
Chris, what was the maximum and minimum frequency you applied to each of the test device you built?
Could  you please answer that?
@Darediamond - Clearly youre not paying any attention!!!
   Chris Sykes
       hyiq.org
darediamond
Quote from: EMJunkie on July 10, 2016, 04:00:23 AM
   Chris Sykes
       hyiq.org
Oh, sorry I did not understand that line earlier. Thank you so much for the timely reply.
Now may I know if it was DC or AC you applied and why?
EMJunkie
Quote from: darediamond on July 10, 2016, 04:12:48 AM
Again this is also stated many times in this thread, in this document: --->>>Guidelines to Bucking Coils. Lenz's Law Free Power Extraction<<<---, and also very clearly seen in my videos!
Both AC and Switched DC Work, each give different slightly different effects, very clearly seen on the Scope.
Like I said, and also Wistiti said, experiment will show this very clearly.
Also stated many times, the Key is the Time Rate of Change of the Flux, thus, Faradays Law of Electromagnetic Induction.
Please, at least read and understand the very first post to this thread before asking questions that have been repeated many hundreds of times throughout this thread: --->>>The First Post to this Thread<<<---
Like I said, all your questions have been answered already, either directly or indirectly in the material I have already provided.
   Chris Sykes
       hyiq.org
EMJunkie
@Darediamond, also, Please carefully study this post: Electrical Energy 101 - Faradays Law of Induction and also the surrounding posts.
I like to think, most all of the posts I have posted to OU.com have an important message to them...
Quote from: EMJunkie on December 20, 2015, 01:55:01 AM
After some 439 Pages, I hope we have now got a message of hope through to people running blindly down dark alley ways!
Induction is Induction, Electrical Energy comes directly from Matter/Mass - This is known as Mass/Energy Equivalence! It is Einstein's E = MC2
Surely the supporting evidence I have provided give's at least some people a step in the right direction:
Electrical Energy 101 - Faradays Law of Induction - Part 1
Electrical Energy 101 - Faradays Law of Induction - Part 2
Electrical Energy 101 - Faradays Law of Induction - Part 3
Electric Motors DC Motors and Generators - Part 1 - 1961 US Army Training Film
Electric Motors AC Motors and Generators - Part 2 - 1961 US Army Training Film
Electricity & Electronics - Current - 1974 US Air Force Training Film
Electricity & Electronics - Voltage - 1974 US Air Force Training Film
How Magnets Produce Electricity - 1954 US Navy Training Film
So, two equations, two ways of Inducing an EMF in a Conductor: EMF = Bvl and EMF = dPhi/dt
Here I show you some basic first principals: Self Assisted Oscillation in a Shorted Coil - Bucking Magnetic Field Oscillation
and, some more Principles: Opposing Magnetic Field Interactions - Partnered Output Coil
Three Coils:
   1: Input Coil
   2: Partnered Output Coils - Two Coils working together to Self Assist in the Frequency of Operation!
A good example of this is given here: Partnered Output Coils: Anti-Lenz effect - from: Юрий Лиховид (Yuri Likhovid) - Orriginally invented by Wistiti - Partnered Output Coil Toroid Feb 25, 2015
Note: There must be Current flowing in the Partnered Output Coils for this to work!
Please, always remember, Lenz's Law is a Magnetic Drag, fix the Magnetic Drag and you have got Free Energy!!! Magnetic Field is Current Flowing in the Coil Conductor.
P.S: When others are set in their ways, its not just their Potential that they limit, its others that listen to their advise. See with Logic and open Eyes, not through others.
I hope many can see that I have spent many hours preparing material for videos and so on here. Doing the best I can to try to cover the most basics to Electricity "Generation"...
   Chris Sykes
       hyiq.org
