0 Members and 63 Guests are viewing this topic.
EMJunkie
A Close up on the Output Coils below:
   Chris Sykes
       hyiq.org
EMJunkie
A Re-Post from here: http://overunity.com/16724/graham-gundersons-energy-conference-presentation-most-impressive-and-mysterious/msg488374/#msg488374
Ok, so, Scientifically, what do we know.
1: Input Winding appears to be 10, 12, 10, 12, 10, 12, possibly only 6 layers, of Litz Wire, about AWG 2 (6.54304 mm) @ approx 0.512664 Ohms per KM.
2: Output Coils consist of 4 Strands of Litz wire, each wound side by side, in a step winding configuration, Almost Bank Winding. Each set of winding's is divided into two parts. Each set of windings appear to be wound CW/CCW relative to the Core.
3: Output is DC, Rectified, via a circuit arrangement of possible 30 odd components.
4: Pulsed DC is the Input. As Reiyuki points out, about 33% 33% 33%
5: Permanent Magnets are arranged on the Device, thought to Bias, or partially saturate at least one half of the U Cores used.
6: U Cores are a Ferrite Material, apparently each has a different value of Permeability. No specifics that I know about have been shared as yet. (The below product guide, has an AL range from: 2300 to: 8700 (nH measured in combination with another ungapped core half))
7: U Core appears to be approximately square, a product selection guide can be found here: Ferroxcube, the largest U Core in this document is in the Picture below: (Which is about right, I have some magnets the same here (25 x 40 x 10) and they would fit about the same on the Core)
All in all, what's the Key concept here? Time Rate of Change of the Magnetic Flux, and the second key point is there are Two Output Coils, arranged specifically in separate space on the second half of the U Core. Electricity is the end result of Electromagnetic Induction, time rate of change, where in the Input Coil is the Prime Mover, which is mostly or completely unaffected by the Drawing of Current on the Output.
   Chris Sykes
       hyiq.org
Good Work Graham!!! If I had 150 Thousand dollars' worth of equipment and the long history of expertise on how to properly and accurately use them, then I would show more. Thanks to you I don't need to!
EMJunkie
Some years back, I shared a Very Basic Experiment, April 2014: http://overunity.com/14378/akula0083-30-watt-self-running-generator/msg398308/#msg398308
No one picked up on this.
EDIT:
I need to clarify, Red Trace is Output (Voltage), Yellow Trace is Input (Current) - Triggering on the scope was not set correctly at the time and some will see that.
Very easy to dismiss this unless you do the experiment.
END EDIT:
Quote from: EMJunkie on April 17, 2014, 12:54:45 AM
Hi All,
Re the NMR Ideas, Maybe. There may be a Quantum component to this but not sure I would say NMR even though I did investigate this. I personally think its 99% Magnetic in Nature, which is directly related to the Quantum in my opinion.
I Posted my first post here: http://www.overunity.com/14378/akula0083-30-watt-self-running-generator/msg398250/#msg398250 Here I have shown the Coils as I have them working. There are a few Characteristics that once you see them you will know you have something very special. I detail some of the Characteristics in the above post.
In my opinion, the best way to describe this 'MAGICAL' effect is in the paper by Paul Raymond Jensen: http://www.hyiq.org/Research/Details?Name=A%20Free-Energy%20Device is where I have published the copied paper.
The quote: "An alternate explanation for the current gain in the UDT is to consider each secondary winding as acting as the primary winding for the other secondary winding when an output current is drawn because the two secondary windings generate geometrically opposing fields." is in my opinion the best description of what is going on from what I have seen.
If you take 1 hour out of your day and replicate what I have shown then you will likely also find the Paul Raymond Jensen paper just as important as I have.
See here: http://www.overunity.com/14378/akula0083-30-watt-self-running-generator/msg398250/#msg398250
All the best
  Chris
Just add Magnets and you can amplify this effect.
Here is the thing, this did not work, unless I used a narrow Duty Cycle, I think about 8% or so here. The core material needed a Relaxation Time.
As most all of you should know, this experiment, the Coils are normally NON Inductive, they should have NO Output in this configuration, but here I show that they DO have an Output!!!
Why? Because the Dot Polarity Flips back, opposing, when the Input turns off!!!
   Chris Sykes
       hyiq.org
EMJunkie
I guess, what I am trying to say, is, there must be a Voltage Potential accross the Coils before Current (The magnetic Field) can do any practical work!!!
   Chris Sykes
       hyiq.org
EMJunkie
Quote from: EMJunkie on July 13, 2016, 12:59:12 AM
   Chris Sykes
       hyiq.org
I can hear everyone asking: WHY?
Well, in every Electrical "Generator", Ohms Law applies, in combination with Faradays Law of Electromagnetic Induction. What does this mean?
Voltage is directly a result of the Time Rate of Change of the Electromagnetic Flux, the Faster the Rotor Spins, the Higher the Voltage!!!   <<<--- This is a KEY Sentance!!!
The Higher the Voltage, the Higher the Current goes, for a given Resistance, this is simply V/R = I!!!   <<<--- This is a KEY Sentance!!!
So, simply, if there is NO Voltage (V), there can be no Current (I) (In an Electrical Generator) through a Resistance (R)!!!   <<<--- This is a KEY Sentance!!!
And so, the wheel work of Nature, depends on, the Time Rate of Change of the Magnetic Flux, The Resistance, The Voltage "Generated" and the Current will follow, only in these configurations.
   Chris Sykes
       hyiq.org
