0 Members and 195 Guests are viewing this topic.
forest
A bunch of coils will generate electricity, magically or not, but when the current is flowing in output coil it acts exactly as you described, however your explanation is correct for one single special case, very hard to setup.Just my 2 cents and I go to sleep again....
EMJunkie
Quote from: darediamond on July 13, 2016, 09:43:17 AM
Chris, life is simple. Sorry for getting you agitated. I guess you have now become an HERO for the heap of insults you have rained on me earlier and now for asking iu simple questions?
Darediamond,
If you had studied, and paid attention to my videos, I show, clearly, how the coills can be wound, I show very clearly, 2 configurations in my pdf that you clearly have not read!
I am no HERO, I have not insulted you, merely pointing out that your here for a free ride and not willing to work for what it is you are after:
Quote from: darediamond on July 12, 2016, 03:52:54 AM
I am not in to "PLAY WITH" But rather looking for permanent solution.
Like I said to you before you posted here, through private message:
Quote from: EMJunkie on July 08, 2016, 04:16:59 AM
Follow this exactly and semd me the link to your video.
https://www.youtube.com/watch?v=iJsVSMQqCOM
https://www.youtube.com/watch?v=phVE5V3pCTc
   Chris
And, still you have not sent me the link to your video. You may be able to tell, I respect those willing to put in the work and think for them selves, working toward an end goal!
It does "agitate" me that someone can ask the questions you have, when I have spent many hours, putting together material, I have already supplied, that has the answers to your questions, already!!!
Do your Homework!!!
Do the experiments!!!
Then ask questions!!!
When you know what it is youre talking about!!!
   Chris Sykes
       hyiq.org
EMJunkie
Quote from: forest on July 13, 2016, 03:17:43 PM
Hi Forest - I see what youre saying, I would perhaps word is slightly different to give a different meaning, perhaps the meaning you intended?
"A bunch of Coils can Transform Electrical Energy"
Voltage and Current in a Transformer get stepped Up/Down depending on the configuration, but Electrical Energy is not "Generated" as such.
The "Generation" of Electrical Energy implies the creation of Electrical Energy, Science will have you believe a Generators shaft Torque is Transformed to Electrical Energy, which is not true.
Not directly...
As we know, Lenz Law creates a Drag, this Drag must be over come by the Shafts Input Torque...
We are dealing with two entirely different beasts however. Shaft Torque is required as an end result of the Generators ability to Invoke Faradays Law of Electromagnetic Induction. But the Electromagnetic Induction itself is a Atomic Process, Mass-Energy Equivalence, the video can be seen here: How Magnets Produce Electricity - 1954 US Navy Training Film of how this process really does work!!!
Also I did a video series on this:
Quote from: EMJunkie on December 20, 2015, 01:55:01 AM
Electrical Energy 101 - Faradays Law of Induction - Part 1
Electrical Energy 101 - Faradays Law of Induction - Part 2
Electrical Energy 101 - Faradays Law of Induction - Part 3
So, Lenz's Law is a side effect, a side effect, of the Flow of Current, that is a result of the Voltage / Resistance already generated by Faradays Law of Electromagnetic Induction (EMF = -n dphi/dt). Its a side effect that we, after some 151 years, since it was discovered by Heinrich Lenz - Lenz's Law only a handfull of people have been able to Break that Law!!!
An example of a device I built, is the Ward Force Generator
I guess, this is a mix of words and intended meaning. Of course what I meant originally, was not just to transform Electrical Energy, but to truely "Generate" an excess of Electrical Energy, in excess of the Input that is supplied.
   Chris Sykes
       hyiq.org
EMJunkie
Because of relivance, I will repost here:
Thanks to Reiyuki's awesome documentation efforts, and for others out there interested, I have done some ID'ing on the IC's
I believe all the Opto's are the same, as the surrounding circuitry is the same. Some appears to be redundant, I may be wrong however.
Red Circles: NEC PS 2505
Green Circle: IXDD614PI
Blue Circle: IL710
Yellow Circle: 74AC14PCX
Please check for yourself, I am not 100% sure on all of them, if is very close if I have not got it spot on.
The Output Caps:
3 x Felsic Aluminum Electrolytic Screw Capacitor 2200µF 350Vcc
2 x Kemet Arcotronics AV MKP C4BTHBX5100Z_L_ Style A 10uf 600V
This is a lot of ciruitry for Synchronous Rectification, Texas Instrunemts has a good doc on this, that is, if this is what Graham is doing?
I hope this helps others that are interested in this!!!
Maybe TK or Chet you like to have a bit of a go at the Circuit? We have scope shots!!!
   Chris Sykes
       hyiq.org
