0 Members and 175 Guests are viewing this topic.
Magluvin
Quote from: EMJunkie on July 22, 2016, 05:28:50 PM
What does a Moving Magnetic Field Create?
   Chris Sykes
       hyiq.org
Listen Very Carefully:
Hey Chris
Listened to the mp3.    Had discussed this with Poynt a while back.
Are there demonstrations that show the E field of a moving magnet that prove this vs field cutting the conductors to produce currents?
Its all easy to say and hear. But how can we visually show it in a sense that we can say, ok, I get it?
Mags
EMJunkie
Quote from: EMJunkie on July 22, 2016, 02:31:52 AM
I have said it, I told you so, this would not last forever...
You, the people of the world are now about to be bound by Patent protection, for a Technology that does not belong to.
Quote from: EMJunkie on April 19, 2016, 10:26:52 PM
I have been comtemplating the release of this for some time now.
Its not fair to limit the importance of this to a select few.
I show the real importance of Coil Polarity on a single Core: What does a Coil really do on the core? - hyiq.org
Study this closely, there is MUCH more going on here than you might imagine. [Protational Field, Mass Current, Lense-Thirring Effect, Spin Wave, Atomic Polarisation]
   Chris Sykes
       hyiq.org
P.S: the door will not stay open for ever, YOU NEED to take advantage of this before its too late!!!
Isnt it ironic, that the threat YOU face(Patent protection), stems directly from the very People that Funded Floyd Sparky Sweet from day one!!! Seems a Link is obvious to those that do their homework!!!
At the same time, Grahams work showing this, Partnered Output Coils as I have shown them, really has proven to many that what I have been saying here for the last few years is true and correct.
Well, there you have it, the Murakmi Army and the Patenting of all the Free Energy Devices of the People: Your Dollars for DVD's Books and all the Marketing BS has paid for your Intellectual Imprisonment!!! You have locked yourselves out...
You, the people are no longer Free!!!
   Chris Sykes
       hyiq.org
Magluvin
   Chris Sykes
       hyiq.org
Hey Chris
Mags
EMJunkie
Quote from: Magluvin on July 23, 2016, 12:16:15 AM
Hey Chris
Mags
Really good question Mags!!!
Try the below picture, I have used this before for different task and it works fine.
Detecting Electric Fields is normally the task of an Electrometer, or an Electrostatic Field Detector, but many are probe dependant and measure Terminal Potential Difference Voltages.
Below is an example of an Electrostatic Field Detector, Handheld that does not require Probes.
Hope this Helps Mags.
   Chris Sykes
       hyiq.org
P.S: I dont know of a way to detect Electric Fields without using some kind of Conductors. I have heard of Chemical methods, where a reaction is exhibited in the presence of Electric Fields, but never seen or been able to find relivant data on it.
EMJunkie
In a Resonant System, LC, LRC Tank Circuit, we will see a Phase Angle between Voltage (V) and Current (I), this we have been through many times before.
The Active Power in the System is Calculated by the following forumla:
   Power (P) = Volts (V) * Amps (A) * Cos(Φ)
Where Phi (Φ) is the Phase Angle between Voltage (V), normally Leading, and Current (I), normally Lagging, in a LC Resonant Circuit.
But what happens if the Input you are measuring appears to be returning more Energy back to the Source than is Supplied? We have been through this with MarkE (In Respect of him), a long way back.
When a Magnetic Field, external to a System, but applied to the System, moves in the System, there is normally a sudden shift, over Time (t). The Density of the Magnetic Field can be calculated with the following equation:
   Flux (B) = Permeability (μ) * Turns (N) * Current (I)
The Energy (E) Stored in the Magnetic Field (B) can be calculated as follows:
    Energy (E) = ( 1/2 * ( Inductance (L) * Current (I) ) )2
Lets say, a Device Under Test (DUT) has the following Parameters:
   Turns: 2x 300 Turns 0.45mm
   Connected: Series
   Inductance: 2.40 Henrys
   Capacitance: 15uF
   DC Resistance: 11.2 Ohms
The following Wave form is achieved:
   Chris Sykes
       hyiq.org
