0 Members and 42 Guests are viewing this topic.
EMJunkie
Quote from: EMJunkie on September 15, 2015, 07:52:04 PM
Bump!!!
For those that do not comprehend, have not been following, but wish to comprehend and follow, to learn something and to achieve a common Goal:
Action: - (Primary Coil) - Your Input. A Magnetic Field, a result of Current Flow in your Primary Coil, that will likely have a Reactive Component. Considered as the Prime Mover.
Reaction: - (Secondary Coil) - Typically considered as a Negative result on the Action. Lenz's Law (the -), a negative result of the Secondary Coil on the Primary Coil.
Counter-Reaction: - (Secondary Coil) - Another Negative result, but this time assisting the Action, the primary, or the Action, but at the same time Countering the Reaction. Lenz's Law (the -).
The two Secondary's are what I call Partnered Output Coils!
These principals can be arranged in many configurations that may result in a working device, and the opposite is also true.
   Chris Sykes
       hyiq.org
EMJunkie
To All:
We have an opportunity, right now, that we really have never had before. People like Brad (Tinman) and Graham Gunderson, have Demonstrated without a doubt Energy Devices/Machines that are undoubtedly Over Unity.
We could change the World right now forever, we have enough to work with, enough to make some real progress, in perhaps the most important step forward Humanity has ever taken.
It is evolutionary, Humans could very soon, look back and wonder how we did not realise such a wonderful Future earlier. We have the Future in our Hands, right now! The Science is real, it's reachable and it's partly known already!
It's the mind of the individual that holds that individual back, realising that YOU have the power, that YOU have the ability to really make some very big changes for the future is the first step to building it.
I ask YOU, Let's do it, let's make this World the absolute best we can!!! Let's Loose the worst Humanity has to offer, and be the Ambassadors we are meant to be, Ambassadors of our Galaxy, a Species worthy of Contact from any other Intelligent Species.
Let's change the Definition of Being Human and make it something to be Proud of.
Together, we can do anything!!!
   Chris Sykes
       hyiq.org
EMJunkie
The Input Signals can be programed reasonably easy: 13 PWM Channels
Small, $14 Microcontrollers can do some amazing things:
Software Control via Virtual Serial Port is easy:
   Chris Sykes
       hyiq.org
EMJunkie
A Repost, from here: http://overunity.com/15307/lenz-free-generator/msg489618/#msg489618
Quote from: EMJunkie on August 11, 2016, 12:17:57 AM
Quote from: EMJunkie on August 10, 2016, 08:25:32 PM
Quote from: allcanadian on August 10, 2016, 03:05:59 PM
Maybe a story might help, a long time ago in a land far away a man named Earnshaw developed a theorem. Earnshaw's theorem and he stated that "a collection of point charges cannot be maintained in a stable stationary equilibrium configuration solely by the electrostatic interaction of the charges". He also believed this applied to magnetic fields and everyone agreed one cannot balance or levitate one magnet on another. Then one day a clever inventor stumbled onto the fact that if the levitating magnet was spun like a top that in fact it could levitate in a stable manner. Some people believed Earnshaws theorem was an irrefutable law which had now been broken while some experts proclaimed the law was not broken. It was not broken because an extra force was present, the centrifugal force of the spinning top was present balancing the magnet and Earnshaws supposed law does not actually include extra forces only free floating charges and magnets. Thus a theorem or law may seem to always apply but only so long as the conditions applicable to the law do not change in any way.
This is very similar to the story of Lenz Law which states that "the current induced in a circuit due to a change or a motion in a magnetic field is so directed as to oppose the change in flux and to exert a mechanical force opposing the motion". Think about that... what does the Law actually say?. A changing magnetic field will induce a current in a circuit creating a second magnetic field which will oppose the first magnetic field change. It does not actually mention the source of the inducing magnetic field being opposed only the magnetic field itself being opposed. Thus a magnetic field source could create a rapidly changing magnetic field impulse then turn off before the field has had time to induce a current in the external circuit and the field source cannot be effected and Lenz Law has not been violated yet the external circuit would be induced by the field change after the source has turned off. Anything less would imply the field change has induced the target before it has actually reached the target which is absurd.
This is the problem with believing things which are not true and reading things into something which was never there nor implied to be there. Lenz said only the "inducing field" is opposed by the induced field no more no less.
AC, this is a very clever post.
Any and every Induced EMF, no matter how many times an Induced EMF occurs, in a single System, has an Effect of the Source, does it not?
But, if the Source is no longer a part of the System, switched out, then the Source is no longer affected, as you say.
How long can a Magnetic Field be kept High after Switch out of the Source?
In a super conductor, indefinitely, for ever in our terms, no Source, but Magnetic Field stays High... Electron's keep going and going and going...
So the Source can change. Not necessarily the Polarity, depending on point of View, but the Location in the system can very easily be changed. This can be done many ways. A common way is to short one coil... This I know you are very well aware of.
One point of view does not make for any proof, how you term:
A Postulate, everyone agrees, with no proof...  Although most experiments might hold, who's to say one wont. After all, Charges are already in constant motion, all having their own Centrifugal forces... Thus making it true that a simple Magnet, will Violate Earnshaw's theorem before this experiment was even proposed - Surely we agree on this point?
There in lays the very basis of how we currently understand the Magnetic Field.
I was surprised to read this post.
   Chris Sykes
       hyiq.org
To iterate a little further, Electromagnetic Induction is a dependency process, for example:
   1: If there is No Voltage, there can be No Current.
   2: If there is No Current, there can be No Magnetic Field.
   3: If there is No Magnetic Field there can be No Electromagnetic Induction.
So, for Electromagnetic Induction to occur, there must be a Source of Magnetic Field, somewhere!!! Time rate of change is a requirement for the Voltage (EMF) Generation, NOT the Current, as mentioned above, the Current is dependent on the Voltage (along with Resistance)!!! It's true, that any Coil that has a Voltage across it (Active Element due to Induction) will be able to supply a Current, regulated by Ohms Law, which will change in Time!!! This is equivalent to a Magnetic Field Changing in Time!!!
Thus any and All Magnetic Fields Changing in Time can be a Source of Electromagnetic Induction!!!
If this Source is equal in Magnitude in comparison to the originating Source, then there will be a net zero effect, or no Tertiary EMF can be "Generated". Thus timing of the Coil Interactions is critical. Capacitance can be employed to do this, or switching if you have the means. Coils can be arranged to also offset this timing.
I hope those that do not already know this will see the importance here!!!
   Chris Sykes
       hyiq.org
   Chris Sykes
       hyiq.org
hanon
http://overunity.com/12794/re-inventing-the-wheel-part1-clemente_figuera-the-infinite-energy-machine/msg489659/#msg489659
Suppose two primaries coils and two secondaries coils in the middle of the primaries.
If the primaries are in attraction mode the only field transversing both secondaries is:
N ---------------> S. As per Lenz, the induced field of each secondary will be <-------- in one secondary and  <-------- in the other secondary. Both opposing to the primary field. How the hell are you going to buck both secondaries? Impossible. No way
If the primaries are in repulsion their fields will be N -------> <--------- N  . In this case one secondary will oppose to its closer primary field: <--------  and the other secondary will oppose to the primary field of the other primary coil:  -------->. There you have two bucking secondary coils. Perfect bucking output coils. In this case you may use pulsed DC. You just need to collide two fields in the center point, right in the point between both secondaries coild, no need for movement of the fields in this design based in flux linking.
Summary :
Attraction  N ------------------------>  S
Repulsion  N ----------> <-----------  S
See this sketch of Daniel Dingel device. The second sketch is drawn by me
