0 Members and 172 Guests are viewing this topic.
EMJunkie
I was not going to post this, but it has merit and value, its a topic we have looked at already, John.K1 bought this up, we did some experiments and proved a good bunch of data...
Floyd Sweet stated:
Quote from:  Floyd Sweet The Space-Flux Coupled Alternator Page: 2
In the specific case of positive charges moving to the right and negative charges to the left, the effect of both actions is positive charge moving to the right. Current to the right is: I = + da+/dt + da-/dt.
Negative electrons flowing to the left contribute to the current flowing to the right.
I think its fair to say, what I was showing, was over looked and those who did look, expected too much without trying to understand what was being said!
   Chris Sykes
       hyiq.org
EMJunkie
If two Currents are 180 degrees from each other, each Magnetic Field will also be 180 Degrees from each other. The Magnetic Fields Oppose Each other!
Quote from: Floyd Sweet Nothing is Something Page: 5
If the directions of the two signals are such that opposite H-fields cancel and E-fields add, an apparently steady E-field will be created. The energy density of the fields remain as calculated above, but the value of the E-field will double from E/2 to E.
Quote from: Floyd Sweet The Space-Flux Coupled Alternator: An Abstract Approach to Abstract Phenomena. Page: 2
Electric fields are due to the presence of charges. Magnetic field effects are due to the motion of charges. Current is the net rate of flow of positive charges.
   Chris Sykes
       hyiq.org
EMJunkie
If you could only see how important this is, what I have shown you!!!
See: Four-quadrant representation of active/reactive power in motor and generator mode
Sign for power measurement
The sign of the active power P and of the power factor cos f  provide information about the direction of the energy flow. A positive sign indicates the motor mode, a negative sign indicates generator mode.
In addition, the sign of the reactive power Q indicates the direction of the phase shift between current and voltage. In Figure 4 this is illustrated in the four-quadrant diagram. In motor mode (quadrant I & IV) a positive reactive power indicates an inductive load, a negative reactive power indicates a capacitive load. In generator mode (quadrant II & III), an inductive acting generator is indicated by a positive reactive power, a capacitive acting generator by a negative reactive power.
   Chris Sykes
       hyiq.org
Enjoykin2017
Hi EMjunkie
Do you take leave  from OU forum ? Maybe plan some exciting gold prospecting in bush with Minelab GPX ?  :D
If not i have some proposal in rearanging MR.PREVA experiment - of course using only Partnered coils and small piece of cooper tube.
To continue or not ? Maybe is not interesting ??  ;)
EMJunkie
Quote from: Enjoykin2017 on September 20, 2016, 07:51:37 PM
Hi EMjunkie
I really was hoping others would show their work and then we could ALL work towards a common goal, move ahead...
Seems no one is interested in this important stuff?
   Chris Sykes
       hyiq.org
