0 Members and 174 Guests are viewing this topic.
Enjoykin2017
Anti J.Joule - E.Lenz Law  The Proof -> White over Black !!  :D
Current density 40 Amps/mm2 will not destroy wire 0.5mm2 , thans non-inductive windings.
Anti J.Joule-E.Lenz Law
http://www.youtube.com/watch?v=ZuJjy9wj9vU
ps: now you know what you need !!
ps2: Laboratory Fact !!
There is zero magnetic-field around supercooled conductor , about several Kelvins higher than absolute-zero even you run 1 Million Amps or higher current through supercooled conductor. Hyper density current free runing while magnetic-field is ZERO.
PURE Anti-Bio-Savart-Lorentz law !!
Good Luck All !!
Enjoykin  :D
darediamond
Quote from: Enjoykin2017 on September 20, 2016, 09:27:03 PM
Yes EMjunkie seems me too - no one interested in Free Energy and Free Freedom !!  :o
But .... to continue interesting experimental story !!
EMjunkie and who is interesting listen (read) carefully. On a copper tube was wound non-inductive winding (form of stacked packing partnered coils) , which covered a part of tube surface , having left at the same distances, parts of tube on both sides from winding ends. The winding wasn't galvanic connected to a copper tube on which it was mounted. The winding was wound by enameled copper wire diameter 0.5 mm.
On a non-inductive winding was given very high current - about several hundreds of amperes - enough current for certainly inevitably destroy wire under such conditions.
But what was happened there was one BIG MR. NO !! :)
Copper tube withouth non-inductive winding was destroyed , but only before winding start and after a winding end. The segment of copper tube on which this non-inductive winding was wound  , remained absolutely safe and not dameged , while the non-inductive winding didn't heat up at all !!
Terminal parts of copper tube, free from non-inductive winding cover ,  were heated up to red heat temperature as a result of influence high short-circuited currents.
Parts of a tube which were covered by winding remained at same temperature what was before current feeding. Non-inductiv windings didn't heat up at all !!
It is obvious that high current which destroyed copper tube and heated free tube ends to red heat , was behaved according to the Joule-Lenz law , but it is also obvious that on a tube section covered by non-inductive partnered windings the same Joule-Lenz law didn't work !!
From these experimental observations is useful to draw some practical conclusions.
1. Tube section which wasn't submitted to influence of Joule-Lenz law (covered and protected by Non-inductiv partnered windings) ,  practically didn't radiated heat , while huge current was running though non-inductive partnered windings.
2.  Free tube sections which were submitted to influence of Joule-Lenz were subjected to thermal overheating and , even to thermal corrupting !!
3. Magnetic-field is directly responsible for thermal radiation and red heating.
4. Final conclusion is simple : non-inductive winding in form of stacked packing partnered coils was a Joule-Lenz LAW-BREAKER !!
ps: Folks - you should be very happy and run a lot of interesting experimenst !!  :D
Good Luck all
Enjoykin
Key word: non-inductive winding
The non-inductive winding is a such winding which rounds , are located in space in such manner that currents in adjacent rounds flow towards each other. Respectively , magnetic fluxes of adjacent rounds are opposite directed , so, the winding has practically , no external magnetic flux and , as a result of it , has very small inductivity – inductivity not appropriate to geometrical form of this winding.
You are sure correct about Noninductive winding which was invented by Mr. Tesla himself.  Yea serially connected Bifillar wire brings about Noninductive Winding. It Multifillar version do bring about extremely high overunity effect.
Kudos to N.Tesla.
forest
Can you download this document please ? https://yadi.sk/i/QD7Ln7QFk3Mkq
Can you translate it into English ?
SkyWatcher123
Hi all, Hi enjoykin, thanks for sharing, any ideas on what experiments could be made , thanks.
peace love light
Enjoykin2017
Hi all !!  :D
My comment about Mr.Yuriy V.Leonov successful work and his explanation Nature of Magnetic Field is here:
http://overunity.com/12736/kapanadze-cousin-dally-free-energy/msg492443/#msg492443
ps: Do experiments - what I need to say more !! You can easy make non-inductive coil with multifillar windings in same configuration like on video and make own experiments. I hope so you have good equipment. You can try all sorts of ferrite cores, electro-magnetic motors, any kind of metal cores even big power line transformers. The results will be exactly like in video. But make clean experiment !!  :D
I wish all good luck.
Take care !!
Enjoykin
