0 Members and 64 Guests are viewing this topic.
EMJunkie
EMJunkie
Electrical Energy is not mysterious, and Systems for "Generating" Electrical Energy are already well known! This we have covered now for a long time.
I see some are picking up this ball and running with it, which is great!
I would like to point out again that all the greats have already been down this path:
Quote from: Clemente Figuera - Infinte Energy Device PATENT by CLEMENTE FIGUERA (year 1908) No. 44267 (Spain)
PRINCIPLE OF THE INVENTION
Watching closely what happens in a Dynamo in motion, is that the turns of the induced circuit approaches and moves away from the magnetic centers of the inductor magnet or electromagnets, and those turns, while spinning, go through sections of the magnetic field of different power, because, while this has its maximum attraction in the center of the core of each electromagnet, this action will weaken as the induced is separated from the center of the electromagnet, to increase again, when the induced is approaching the center of another electromagnet with opposite sign to the first one.
Quote from: T. HENRY MORAY THE SEA OF ENERGY IN WHICH THE EARTH FLOATS
An electrical generator is, in the true sense, not a generator, as it does not create electrical energy. Electricity is not made by the generator, it is merely pumped. From that standpoint, an electric generator might be referred to as an electric pump and the Moray radiant energy device as a high-speed electron oscillating device.
Quote from: Floyd Sweet - The Space Quanta Modulator: How it Works
As the time varying flux of a period of 1/400 or 2.5 milliseconds sweeps over the stationary armature coils, voltage is induced defined by Faraday's law.
AND:
The number of turns per coil is determined by Faraday's law as quantized by Neumann.
Quote from: Floyd Sweet - The Space-Flux Coupled Alternator:
When the rotor magnet assembly is driven by a prime mover the rotating magnetic field sweeps over the conductors comprising the coils in the stationary armature, sometimes called the stator. As the direction of the flux reverses during Delta t, the induced output waveform is sinusoidal. The induced voltage in the winding obeys Faraday's law as quantified by Neumann Eav Phi/t  10-8 v. This is average value and must be multiplied by 1.11 form factor RMS effective volts.
Electrical Energy is right there, ready for you to Invoke it, the Magnetic Field is engineerable! SuperPosition, Two Magnetic Fields that Oppose, is the key to making the Lenz's Law problem go away. I believe we have covered enough that all should know what to look for and move ahead.
All this is SO Important, it is our future!
   Chris Sykes
       hyiq.org
EMJunkie
But:
Quote from: EMJunkie on July 13, 2016, 03:28:49 AM
I can hear everyone asking: WHY?
Well, in every Electrical "Generator", Ohms Law applies, in combination with Faradays Law of Electromagnetic Induction. What does this mean?
Voltage is directly a result of the Time Rate of Change of the Electromagnetic Flux, the Faster the Rotor Spins, the Higher the Voltage!!!   <<<--- This is a KEY Sentance!!!
The Higher the Voltage, the Higher the Current goes, for a given Resistance, this is simply V/R = I!!!   <<<--- This is a KEY Sentance!!!
So, simply, if there is NO Voltage (V), there can be no Current (I) (In an Electrical Generator) through a Resistance (R)!!!   <<<--- This is a KEY Sentance!!!
And so, the wheel work of Nature, depends on, the Time Rate of Change of the Magnetic Flux, The Resistance, The Voltage "Generated" and the Current will follow, only in these configurations.
The VERY Funny thing is, even some smart people are catching on to this: http://www.overunityresearch.com/index.php?topic=3345.0 - Smudge, Youre a Smart Bloke. Tell me now that I am wrong ;)
Hahaha some will be V-Lining for the shaddows now!!! Chet, youre still a Dick!
Erfinder, Stop theiving my work and concepts!
Can you feel that? I done insulting resident Gooses!
   Chris Sykes
       hyiq.org
                             electro static/electret                     magneto static/magnetret
                                                           dox/Dogma/Teach
        anti=Para
                                                              PARADOXON
https://www.google.pt/search?client=opera&q=hydrostatic+paradoxon&sourceid=opera&ie=UTF-8&oe=UTF-8#q=hydrostatic+paradox
                                           electro-magneto static paradoxon
https://www.google.pt/search?client=opera&q=electro-magneto+static+paradoxon&sourceid=opera&ie=UTF-8&oe=UTF-8#q=electro-magnetic+static+paradoxon
https://www.google.pt/search?client=opera&q=angular+momentum&sourceid=opera&ie=UTF-8&oe=UTF-8
                                                            angular momentum
                                                  idiom and meaning to differ between
quantum mechanics        (classical) physics
                                          https://arxiv.org/pdf/1607.03837.pdf
EMJunkie
Yep, knew it!!! Hook Line and Sinker...
The proof is right there, they come searching!!! Because they got nothing!!!
One via PM, one via UnWanted verbal diarrhea, which is all we expect...
   Chris Sykes
       hyiq.org
