0 Members and 114 Guests are viewing this topic.
wistiti
 :) Happy to read that itsu!!! Have you mesure the primary power with the load at the output vs no load at the output? Does it reflect the exact difference the load consume?
Thank you!
Lostfox, you are really Lucky guys to have found this perfect fitting coil!!!!! Can waith to read about the result they give! :D
itsu
Wistiti,
when i remove the load resistor (470 Ohm), the input power drops from 665mW to 580mW, so only 85mW less.
Itsu
wistiti
So only 85mw diference for a output of 533mw...
Seems good! So the load not completly reflect on the output. :)
SkyWatcher123
Hi all, Hi itsu, thanks for sharing your work, you could try the sucahyo pulse drive circuit, here is the circuit i've been using, though you can leave out the diodes in the charging section, since you will be using the output of the partnered output coils.
Also,, i have started a thread at the other forum called, phase shifted induction, it is showing that just like thane heins work, if a certain minimum frequency is reached, the reflection back to input source stops and even decreases.
I'm using the same 3 coil setup i used in the bucking inverter thread or partnered output coils.
peace love light
wistiti
Hey Sky! Itsu a real pleasure to see you are still on it :)
Will you share some of your experiment in this forum to?
Take care!
