0 Members and 109 Guests are viewing this topic.
tinman
Quote from: hyiq on February 04, 2017, 06:58:23 AM
Its easy to see why we have been "In the Dark" for so long! Stupid Old Two-Bit Losers that can only manage a thought experiment in their rocking chairs, in old peoples homes...
Hey MileHigh, try telling Clarke Hess they don't know what they are doing you stupid old FOOL!!!
Here is two more INDEPENDANT REPLICATIONS that only you could try to dispute, and true to your natur look stupid doing so:
What a complete joke, there are some completely stupid in the head morons around!!!
   Chris Sykes
       hyiq.org
Quote GG
3 Coils, Load, DC Switching(H-Bridge LC Tank) - Overunity: 5.7
Measured on Tektronix Scope X1 and X2 Clarke Hess Watt Metre (Try telling Clark Hess they have bad equipment, they will serve you!!!)
2016 Energy Science & Technology Conference
Is this the same test where GG bypassed the current input to the Clarke Hess Watt meter?.
Where is GG now
What has happened to his wonderful OU transformer?
Did you read my previous comment?
Brad
tinman
Quote from: hyiq on February 04, 2017, 07:11:48 AM
Brad, no, no In/Out measurements were given, a single scope shot was provided, but I gave no data on measurements. There is no way that any correct In/Out measurements could have been devised!!!
Yes, DC and AC Coupling has been shown many times on my scope shots, posted here and else where. Tinselkoala admitted it was ok in the end of that big deal made over nothing!
I told him I had checked for DC Offset and there was none. So, although the Metrologists will like you to provide AC Coupled Shots, it is only to eliminate a few issues that they should ask to see separately anyway.
So, all in all a big deal was made over nothing, like is always done!
   Chris Sykes
       hyiq.org
Well this is good Chris.
Maybe it is time for you to put up some accurate P/in P/out test measurements ?.
If i had a clear description of your best OU transformer,i would be happy to put one together,and provide my finding's,as the new workshop is a hoot  ;D
Brad
hyiq
Quote from: tinman on February 04, 2017, 07:17:07 AM
Quote GG
Where is GG now
Brad
Brad - I can see that you have not watched the video? I thought you did? We did pass words on this sometime back...
What by-pass???
   Chris Sykes
       hyiq.org
hyiq
Quote from: tinman on February 04, 2017, 07:20:10 AM
Brad
Odd, yes I got defensive. Your tone, the statements you're making even when you know better...
   Chris Sykes
       hyiq.org
hyiq
Ok, so an updated list of Achievers: Independent Replications all of varying levels and stages, some by Independent Researchers.
Quote from: darediamond on January 15, 2017, 03:08:25 AM
Chris is right. Bucking coil when properly connected have no lenz at all and still gives output.
You can all see that my set-up is fucking Crude or rough. But still I get the effect. I loaded the secondaries and still there is no increment at all in the input wattage.
The whole P.O.Cs is covered by the primary.
You need to separate the charge by applying Vladimir Utkin Circuit which he stated in his PDF document under the title "Switchable Iinductance"
I am now moving away from that circuit to test full bridge and earthing circuit to see if I will able to draw current from the Earth Crust with or without Avramenko Plug.
Frequency to the primary from my mechanical switch was under 30hz
Input voltage to my primary was 90 volt DC.
The output wattage I crease as I increase the frequency. But MY LOAD WHICH IS A DC MOTOR DID NOT AFFECT THE INPUT WATTAGE AT ALL. I REAPEAT AT ALL.
Now time to test Bucking  primary and one secondary as come.
I will also test single strand primary coil over the bucking secondary to see if the output watt will drop or not as I notice using neodymium magnet that current flowing in Multifillar wire mimicks AC zig zag or push pull even if the current is DC.
Thank you Chris, Vladimir Utkin, Marathonman, Hanon, Though and all you other people on over unity.com for your selflessness and sincerity
Quote from: Graham Gunderson link=http://emediapress.com/grahamgunderson/mit/
Quote from: Graham Gunderson link=http://grahamgunderson.com/ou/
3 Coils, Load, DC Switching - Overunity: 1.01
Measured on Tektronix Scope X2
2015 Energy Science & Technology Conference
Quote from: l0stf0x on October 11, 2016, 05:53:35 AM
Hey all, I have build a simple joule thief using bucking coil arrangement that I wound my self.. It looks very productive and I wanted to ask you if this it is "something"! or if its a common result.
Output from secondary coils are passed through a bridge rectifier to have dc for taking measures. (direct from battery VS through the circuit)
The load is 3 leds on a pcb with a BR, few resistors and a mini electr. cap. (Its the head from a hand crank flashlight)
Batery is a 18650
I made some measures..
Direct the load to the battery: 3.70V --- 0.58mA  ---> 0.2146 Watt
Through the circuit:                4.90V --- 93.2mA  ---> 4.5668 Watt
That's 2028% difference..
The loal direct to battery is very very dimmed..
Through the circuit is so bright that you can't see it directly.. near to burn I guess.
Quote from: Mark Balanger Advanced Electronic
https://www.youtube.com/watch?v=CPgnKpScGDA
Published on Dec 4, 2015
This difficult to tune circuit really does work. Once folks try to utilize my method of building and tuning, it will make life a lot easier to get one functioning. A magnet is used to change the flux path of the device once it is powered up, and, it seems that once used in a few different areas, the longer it remains powered and the frequency is found per size of the load, a device will need to be used for eacdh large device we utilize without the danger of being charged for that amount. Since this device uses from the uA to the mA range of idle current it is vital to know it can be used for very large loads such as continuous water or fuel pumps, and, many other devices.  Why aren't we building them for power in our homes ?? The coils use minimal idle amperage like wall wort power supplies, but at a much lower amperage. When we add load, the amperage dropped.  The more we add. The lower it goes. This cost me $2.25 worth of ferrite and copper to make.
Quote from: Wistiti
www.youtube.com/watch?v=RKfr8bwVhkc
Published on Feb 25, 2015
There is my second video on youtube!
In this one i tried the partnered bucking coil presented by Chris Sykes "EMJunky" on an already made toroidal transformer...
The only thing i would like to add is Thank you Chris!!!
Quote from:  Юрий Лиховид
https://www.youtube.com/watch?v=jWzZqw8eLDU
Published on Sep 4, 2015
A little-known "Aharonov-Bohm effect" (1959) is working against the old and known "Lenz's-Law" (1833). The result is an "anti-Lenz" effect.
Soon will be a video: "Anti-Lenz effect - the final version".
Quote from: Thaelin on December 09, 2015, 02:16:31 AM
Yuri did what I did, and got the same results. It baffels you to see it.
Even worse, is when you try to prove yourself wrong and the results
hold rigid.
Now lets see how bad the pack tears this one up.
   Chris Sykes
       hyiq.org
