0 Members and 130 Guests are viewing this topic.
dieter
@ Chris,
sorry still not getting it.
If the fields a congruent, or mirrored, they neutralize eachother, regardless of the pulsewidth i guess.
However, if one of the buckers is 90deg shifted in phase (assuming sin wave), it will induce with a max efficiency. But the back emf of the pickup coil that is sandwiched between the buckers, will be shifted 90 deg further, or 25% of the cycle later, which is precisely the moment and polarity the other bucker fires his primary magnetic impulse, so it adds to it.
This amplified impulse causes again a yet stronger back emf on the first bucker, that again adds to the second bucker.... this is where I tend to throw in the term "runaway situation", the thing may explode ^^
Some ASCII gfx:
______
B1 P B2
B1 and B2 are the bucking coils, one with 90deg shilfted phase by a cap of correct capacitance. In the middle an ordinary pickup coil. Signal in is sinus wave.
hyiq
Quote from: dieter on February 16, 2017, 09:34:46 PM
@ Chris,
Some ASCII gfx:
______
B1 P B2
Hey Dieter,
I am going to have to disagree: Delay Line
Quote from: Wikipedia link=https://en.wikipedia.org/wiki/Analog_delay_line
a device producing a specific desired delay in the transmission of a signal.
All transmission of Electromagnetic Energy, especially what we are doing should be thought of as Waves, or Signals, we can manipulate then as required. Phase Angles, Delays, or lack of. And so on...
Magnetic Pressure, like a Turbo, Air Pressure, is an Out of Equilibrium situation, where we can exploit the Force involved. Like a Hydraulic Ram Pump, Gravity puts Water Flowing Down Hill under a Pressure, as a result of some very smart and simple engineering we can use this pressure to pump Water back up Hill. No Power needed, no End User action required, and no hidden battery's...
The Hydraulic Ram Pump works all day long, all night long and will continue to work as long as there is no break down in the device/supply of Energy. This is the Ultimate Nature Powered Machine: The Hydraulic Ram Pump
What is Lenz's Law in an Electrical "Generator" - we are doing the same exact thing here.
   Chris Sykes
       hyiq.org
dieter
partzman
Quote from: hyiq on February 16, 2017, 08:04:51 PM
Partzman, Brad and others interested:
Something very important to see, is the above quote. Partzman's experiments are correct, but incomplete.
For example: In a completely Non-Inductive Coil, there is no Voltage Induced, we all know this, but there is actually a way to Induce Voltage in the Non-Inductive Coil, and if there is Voltage, then there will be Current...
One example we all should already be familiar with is Tariel Kapanadze... How does he Induce Voltage in his Non-Inductive Coils?
Yes, that's right, by injecting a very short Nano Second, High Voltage, Pulse into his Coils via Electromagnetic Induction. Thus the importance of the Nano Pulser we have all studied. The term Non-Inductive is a Miss-Nomer! It is actually incorrect and Miss-Leading!!! Non-Inductive is actually about as Inductive as you can get!!! The problem is, Nature does not want to fly to pieces and an Equilibrium is achieved by ensuring the Balance of Forces at most levels.
Thus my post, I only partly agree... It seems we still have a lot to learn about Electromagnetic Induction, I most certainly do not know as much as I would like to know, although, one has voted 100%
   Chris Sykes
       hyiq.org
P.S: Question: If the Magnetic Field is Present, and in Opposition, but does not Change in the immediate Space that Conductors are present, can Electromagnetic Induction Occur?
Chris,
We all have more to learn concerning electromagnetic induction.  Two authors on the subject I find most enlightening are Edwards and Saha.  I've attached two of their papers below.
pm
MichelM
Chris,
So for Luc's replication, if I understand correctly, is this the right connection ?
