0 Members and 117 Guests are viewing this topic.
ramset
Chris
Quote to Luc
What I do know, is you broke the rules of my private forum when you shared information with Chet K about our private experiments
end quote
@Chris
never happened , this is a complete fabrication
I NEVER ASKED FOR or was ever given one dot or tittle of information from Luc on any experiments performed at your private group.
Zilch Zero Nada...
at the very least... you Owe Luc an apology
Chet K
Thanks Grandma
hyiq
Quote from: itsu on February 18, 2017, 05:04:34 PM
Chris,
Thanks for clearing up the coils naming.
i however still am confused as i think you seem to mix up a series LC (see your impedance/Phasor diagram) and a parallel LC (which we have here).
In parallel LC circuit at resonance we have only a resistive load (maximum impedance, so minimum current) therfor NO phase difference, meaning 0°.
http://hyperphysics.phy-astr.gsu.edu/hbase/electric/parres.html
Anyway, i redid some measurements using the current probe (i compared it to a 1 Ohm resistor in the input lead which seems to agree) and it shows
that this way we have a more reliable outcome (no more "flip overs" seen).
At resonance (6.2KHz) input current and voltage are exactly "in phase", meaning 0° as it should be in a parallel resonant circuit.
Input voltage peaks and input current dips because of the maximum impedance at resonance.
Dieter,
I added a 220uF bipolar electrolytic capacitor to the 1uF cap as requested.
The resonance frequency dropped to about 380Hz but the currents through the coils seem to be more or less "in phase" instead of 180° out of phase.
For what it is worth.
Video here:  https://youtu.be/30oujoUF2Uc  (uploading another 20 minutes).
I want to try some further measurements (like with a hall sensor to measure the magnetic fields) before going to the next step (3th coil etc.).
Itsu
Hey Itsu - Yes, there are Parallel (Maximum Impedance) and Series (Minimum Impedance) Resonance Circuits. See Picture Below:
So, what's Impedance (Z), the Equation is: Z = R + jX
Where:
   Z is the Value of the Impedance
   R is the Resistance in Ohms
   j is the imaginary component
   X is the Reactance
So both Circuits still have a Value of Reactance (X), both Capacitive (XC) and also Inductive (XL).
So, I hope I can clear this up, there will be a 90 Degree phase shift, no matter weather Series or Parallel Resonance is achieved, see below Experiments. P.S: I did this rough, quick experiment just for you Itsu, I hope this is useful!
   Chris Sykes
       hyiq.org
hyiq
Quote from: ramset on February 18, 2017, 06:25:28 PM
Chris
Quote to Luc
end quote
@Chris
Zilch Zero Nada...
Chet K
I have never told any lies, ever!
http://overunity.com/15395/partnered-output-coils-free-energy/msg491630/#msg491630
Read and weep Chet K, for it is you that owes GotoLuc an apology, for pressing him for Information. In the process, through a complete circle of incomplete dialogs... Storeys got mixed up and falsified. Which You Chet K were part of!!!
   Chris Sykes
       hyiq.org
gyulasun
Hi Chris,
I can see three problems.
1) your 4.92 uF and 0.24 H should resonate on 146.46 Hz and not on your FG's input of 270 Hz (if you set the FG to 270 Hz, that is)
2) your chosen current measuring point in the parallel resonance circuit is not correct: you actually check the coil current and not the input current going into the parallel LC circuit. In this circuit you should insert the current sensing resistor in series with the generator, say in its GND wire that goes to the bottom of the paralleled LC , and not in series with the coil
3) your chosen voltage measuring point in the series LC circuit is not correct: you actually check the phase shift of the capacitor. In this circuit the test point for the voltage is the direct FG's 'hot' output itself.
Gyula
ramset
Chris
I have never told any lies ever
end quote
Lets get into this shall we ?
please start a thread for this as you have been intimating and outright calling many persons here thieves and liars controlled By
Mark Golds and even recently said Stefan Hartmann controls or Manages this nefarious figment of your imagination
or was the most recent example of Brad working under this make believe group not a Lie ??
you owe Brad an apology too
Chris
the truth will set you free
you have made countless false accusations against many members here
I see your link above leads to edited content
« Last Edit: September 13, 2016, 02:03:59 AM by EMJunkie »
a quite typical example !!
START A NEW THREAD
or maybe just man up with your claims/errors here and get this behind us once and for all
its your call
Thanks Grandma
