0 Members and 97 Guests are viewing this topic.
hyiq
I think this is worth a Re-Post:
Isn't it funny, how the OU Goons start turning up - Timed entry!!!
One, Two, Three...
I was speaking with a friend who is a silent reader, the comment I received was: "they are desperate"
It is funny how people hold themselves when faced with imminent destruction - There is no room for the OU Goons anymore, you're all so see through, you're all so desperate, and so fake...
Now, here in lays another very big mistake: Call this evidence if you like!!!
Quote from: tinman on February 05, 2017, 07:41:52 AM
Mmm-ok
First results are in for the below setup.
This was a quickly wound transformer-so not very neat,and only low power applied,by way of my SG. The loads are two identical !grain of wheat! incandescent bulbs.
Unlike Wistiti's setup,i did not join the two output coil's,but rather placed a resistive load on each coil separately.
EDIT-i forgot to mention--to achieve these results,i had to use a square wave,and a frequency of 12.2KHz.
Still looking for the error,but here are the results so far-measured with both DMMs and scope using a CVR.
The scope and DMMs had only a 2% difference with value's,so an average was taken from the both results.All DMMs were swapped around,and came within +/- 1%
Tried using the clamp on meter,but currents are to small to register.
P/in-6.8vRMS @ 19mA=129.2mW
P/out 1-1.8vRMS @ 41mA=73.8mW
P/out 2-1.83vRMS @ 42mA=76.8mW
So seems to be running at 116% efficiency.
We are close to being within error range with such small currents,but none the less,all care was taken when making the measurements.
I will report back when i find the error-which seems to be oddly elusive ATM.
Brad
Sorry for the quick crappy diagram,but have lots to do ATM.
Also added a pic of the toroid,and as you can see-very crappy winding job.
And then a rebuttal:
Quote from: tinman on February 19, 2017, 08:32:49 AM
Well Chris-no cigar here-i found the error--> 2 incorrect value CVRs is all it took to throw the readings out.
At these small power values, .2 of an ohm can make a big difference.
So,my P/in CVR was .9 ohm's,and the P/out CVR was 1.1 ohms-well as best as my best DMM could make out. Both are banded as 1 ohm.
Brad
Input:
V: 6.8
I: 0.019
R: 357.89474
P: 0.1292
P1:
V: 1.8
I: 0.041
R: 43.90244
P: 0.0738
P2:
V: 1.83
I: 0.04197
R: 43.60547
P: 0.0768
Now, If I change any one of the Resistance Values by the error mentioned: 0.2 Ohms What end result do we get???
Yes, Ohms Law does not LIE!!!
You, the Reader, you are being deliberately Miss-Lead, strung Up, by Paid For Liars and Cheats!
   Chris Sykes
       hyiq.org
hyiq
Quote from: partzman on February 19, 2017, 04:53:55 PM
Within all the mud slinging there may be a ray of sunlight trying to shine thru!  Has anybody taken a close look at Itsu's video with the re-positioned current probe?  Only Itsu can answer this but if his sense resistors are accurate say within 5%, his measurements indicate OU with reasonable scope measurements.
I've attached a scope shot below of what I'm referring to.  Keep in mind that the current measurement is 10x so it is really 109.6ma rms and in phase with the input voltage of 1.431v rms. This equates to a Pin of 156.8mw rms.
The outputs are 136.6mw for CH1 and 42.77mw for Ch2 for a total Pout of 179.37mw for an overall COP = 1.145.  This efficiency is high enough to warrant more investigation IMO.
pm
Hey Partzman,
Thank You for posting something sensible and of use!!!
A very quick look over your figures, I would see no immediate problem there.
However, this is not my experiment and I don't know what the Probes are set to for sure, and or the accuracy of the resistors. Maybe they too are 0.2 of an Ohm in error?
I do see a small phase angle difference however, maybe 10 Degrees or so, between the Input Voltage and Secondary Currents.
   Chris Sykes
       hyiq.org
partzman
Here are my results of testing a replication of Itsu's circuit using 50mm ferrite toroid wound with 18t and 36t counter-wound windings.  The resonance cap is a 1.98ufd Wima MKS film and the sense resistors are Caddock 1.00 ohm 1% non-inductive film type.
Great care was taken with calibration and measurements as follows-  A Fluke 515A calibrator was used to check the accuracy of the 1v and 10v AC ranges of an HP 3455A volt meter.  The 1v range displayed 1.0007v ac at 400 Hz and the 10v range was 10.0099 at 4kHz.
The voltages measured across the 1 ohm load resistors were then compared to the HP 3455A measurements.  The current probe was also checked by measuring the current thru each load resistor and comparing to the voltages measured by the scope.  The Math channel was used to calculate the input power and was compared to snapshots of CH1 and CH4 with cosine correction of the small phase shift.
The measurement comparisons are as follows-
Tek CH2 .5827v rms
HP 3455A .5889v rms
Current Probe .5723A rms
Tek CH3 .3048v rms
HP 3455A .3050v rms
Current Probe .3005A rms
The "Resonance Measurements" scope pix shows the waveforms of interest.  Math indicates the input power to be 461mW.  CH2 output voltage is 586.2mv which calculates to 343.6mw and CH3 is 305.2mv which equates to 93.1mw for a total output of 436.7mw for a COP = .947.
For an input power comparison, the snapshot for CH1 showed a level of 2.066v rms and the snapshot of CH4 indicated 223.2ma rms.  Therefore 2.066 x .2232 x cos(.189) = .4611w.
Overall the current probe seems to be low in measurement accuracy by 1.4% to 1.8% compared to the scope which would increase the power input and lower the COP if the measurements were corrected.  So, IMO, this device as presented is conservative.  Also this device is not equal to the Preva device in the fact that the bucking windings are connected in-phase with the dotted ends connected together.  As far as I can tell, this would also be similar to the devices tested by Tinman and gotoluc.
If anyone is interested in the scope pix showing data mentioned but not displayed let me know via a PM.
pm
hyiq
Quote from: partzman on February 19, 2017, 09:14:09 PM
Tek CH2 .5827v rms
HP 3455A .5889v rms
Tek CH3 .3048v rms
HP 3455A .3050v rms
pm
Hi Partzman - Thank you for taking the time to replicate and share your results.
Question, none of the waveforms show an exact 180 Degree Phase Shift like was in Itsu's Wave forms. Itsu's wave forms showing a very clear 180 degree phase shift. I was also able to get the 180 degree phase shift.
Your results on your MrPreva circuit are better than mine. I got 82% - Like I have said on many occasions now, the MrPreva Circuit by itself is not OU!
   Chris Sykes
       hyiq.org
Edit: Must be the Colours, yes I see now: Teal and Pink Wave Forms... Nice Work - So, what next then, what's the next step?
P.P.S: WOW, what an amazingly, throughly dedicated, very specific focus on accuracy Partzman... I know some of your background, but really, is this because Tinman was caught, again, Miss-Leading the masses? Come on, be honest, do you work for, take orders from or have you had any kind or direction from Chet K or any Minion that does the said biddings for?
hyiq
I think this is worth bring up at this point, as none have bought this up really at all.
I have on many occasions shown an Output, where my Input is not affected, at all by the Loading/Shorting of the said Output other than at the immediate connection and then a rebalancing.
So, simply, My Input was not Loaded by my Output I have shown for many years, a complete disconnect from Input to Output!!!
Flux Gate Magnetometer standard Practice...
   Chris Sykes
       hyiq.org
