0 Members and 68 Guests are viewing this topic.
Mr.Miyagi
I am an author with an EE background.
There is a storey that needs to be told here. This could be my next book.
leonelogb
Amen Sir, we'll love to hear it!
Quote from: Mr.Miyagi on December 01, 2018, 04:16:30 PM
forest
Mr. Miyagi
Yes,it is world changing...if people would want to change. However this ruin their business ,that's why it's suppressed. It's like the simple cure for cancer - it can't be simple because too many people would lost their jobs :-( It seems that current world must sink to allow free energy to re-surface....
Mr.Miyagi
Quote from: leonelogb on November 26, 2018, 01:52:10 PM
AND THE WINNER IS Chris Sykes - hyiq.org
https://arxiv.org/abs/1802.00832v1
https://www.uibk.ac.at/newsroom/first-diode-for-magnetic-fields.html.en
    Lorentz reciprocity establishes a stringent relation between electromagnetic fields and their sources. For static magnetic fields a relation between magnetic sources and fields can be drawn in analogy to the Green's reciprocity principle for electrostatics. Here we theoretically and experimentally show that a linear and isotropic electrically conductive material moving with constant velocity is able to circumvent the magnetic reciprocity principle and generate infinite magnetic isolation. This result is demonstrated by measuring an extremely asymmetric magnetic coupling between two coils that are located near a moving conductor. The possibility to generate controlled unidirectional magnetic couplings breaks down one of the most deeply-established relations in classical electromagnetism, namely that mutual inductances are symmetric. This result might provide novel possibilities for applications and technologies based on magnetically coupled elements.
@leonelogb,
You are right. Member 'l0stf0x' and 'EMJunkie' ( Chris ) were talking Magnetic Diodes some 2 years before the papers were submitted, 30 Jan 2018. This is amazing.
Quote from: l0stf0x on November 09, 2016, 02:16:44 AM
Hey EMJunkie, you are very welcome, But I did the obvious!
What we do here is for common good.. sharing is the strong base to build.
Mr. Bedini by the way was a great paradigm of sharing.
This explanation from Floyd Sweet fits exactly with the magnet's roll is our system.. the tidal kinetic energy in our case is the magnetic field of the magnet !!
Actually there are 2 cases of how the magnet could be helping in the system. One is the example you post.
and the other is the case of .. the magnet act as stopper of the smaller tidals that are coming from the opposite direction of the ships direction (using your example), something like magnetic diode imagine. Because if you add another one on the same core either by extending the strength of the first one or either applying it on another point on core you get either no change or more input current needed.
This needs testing too :)
But in any case of the two the magnet's field helps.
Thank you EmJunkie, You are leaving library!! You scare me some times ;)
Quote from: EMJunkie on November 09, 2016, 03:19:31 AM
P.S: A Magnetic Diode is a good analogy! I like that.
