0 Members and 88 Guests are viewing this topic.
alan
we should stop discussing and nitpicking and start verifying if Chris is right, he kept it (too) simple and kept it basic, so no excuses can be made.  :)
If he is wrong, I give up on free energy and go on with my life.
gotoluc
Quote from: EMJunkie on January 21, 2015, 04:01:23 AM
Hi Luc,
You can see in this video: https://www.youtube.com/watch?v=ZhQgch4L5XY
Output Voltage goes up to 5.453 only after a few seconds of tunning. This is with a Resistive Load. Voltage and Current must be in phase through a Resistive Load.
A Resistor will not make any difference to this device, in fact if the resistor is wire wound it will not give an accurate result.
Without doing a rebuild on this device, as it is now parts in a box somewhere, re-building is a bit impractical.
I have however attached a Picture to show the RMS Voltage from the Video I have posted online at the above address.
I am not going down the "Measurement" path - Bill Alek a qualified EE has been ridiculed without any evidence to the contrary. My measurements are not up for debate here.
I am giving people the How's, Why's and the Secrets to build their own Devices. Its up to them to make their own decisions.
I encourage people to use their Common Sense and decide for themselves if this device makes sense and is worth the 1hr and $20:00 to Build and Learn.
Kind Regards
   Chris Sykes - hyiq.org
   To Reach New Horizons!
Hi Chris,
I do understand that you have a resistive load in your video. However, we don't know its resistive value so it's not possible to do any power calculations.
As you point out, you don't want to use a wire wound resistor to do this test either. Please use a carbon or metal film resistor. Also, I don't think cycle RMS is what you want to measure. Just use VRMS.
If you look at all my tests I offer power calculation to the best of my knowledge and ability. So I don't know why you would not want to do the same. I don't agree this is $20. worth of parts. There's a lot of equipment needed to do this test correctly. How much does your input power supply and circuit cost?... How much is a scope?... you have all what is needed yet you refuse to pay $2. for a few 5 Ohm 2W metal film resistors to do the power test correctly?
Something is not right  :(
Please help your topic start out right and reconsider this
Thanks for your time
Luc
EMJunkie
Quote from: vasik041 on January 21, 2015, 05:53:52 AM
I find this quite unfortunate. I can't understand why you doing it this way.
@Vasik041
Really? Too Bad - I will go about things the way I see best! I am an adult and can make my own decisions!
Why you don't want support your claims with real experiment and measurements ?
Your distorted view of the truth is just funny! I have done the Experiments! I have done the Videos! I have documented my work and made diagrams and so on to support it all. I have pdf documents showing Photo's showing My Work and others work that follow the same lines!
But instead asking people do their own research...
No! I am asking people to learn it, build is and share it! I am the one that has done all the hard work! Spent many thousands of hours and dollars making devices work! Now I share my work.
I perfomed myself tests with such setup and I saw many other test reports. Almost all OU measurements turned out to be a mistake.
I am sorry for your result! Maybe you can do better next time? Maybe I can give some advise, don't give up so easy!
Truth doesn't fear investigation  :)
Now why do you think I would go to so much trouble to document, make pictures, take the time to post here, help others out, ALL Free mind you. Why?
I say to people, if you're afraid to go sailing for fear of falling off the side of the Earth, the flat Earth Theory was proven wrong many years ago!
Kind Regards
P.S: I started this thread for those interested. If you're not, and have nothing constructive to add. Kindly do not visit this thread!
alan
Billiam offers 2 years warranty for his products, I think this tech is real.
I asked for a demonstration of the 'never needs to be charged' Jetson scooter in the Netherlands, and I need one for myself.
http://auroratek.us/PRODUCTS.html
EMJunkie
Quote from: alan on January 21, 2015, 09:24:26 AM
Stan Meyer used a similar setup with his charging chokes, he said it was like that 'to limit current', but with your findings we want more current (for more power), only it must not be feedbacked to the input coil (Lenz).
Someone else (user nav) has played with bucking coils before you made your findings known:
http://youtu.be/qT-t6LpYbEc
he made a monopole magnet with it:
http://youtu.be/4T2jyC6N0_g
@Alan,
Thanks for sharing the links!
This is a very good demo! He has not quite got the configuration working correctly! He needs a closed Core like Stan had, an Iron Bar in a U Shape is not the best.
Yes, Stan did use this configuration! I have shown this in my pdf!
Kind Regards
