Raycathode
Now, who is the novice having an ignorant tantrum?
your cartoons mean nothing if you want to play the Marconi game fine! bye-bye, you have a long way to go
Anti.Semitic
Quote from: Raycathode on February 12, 2020, 03:22:33 AM
I gave you the truth. take it or leave it. no tantrum.
some would rather chase rainbows, that's fine with me.
Anti.Semitic
Quote from: Anti.Semitic on February 11, 2020, 09:54:44 PM
what is pressure to a charged particle? how does a charged particle behave under pressure?
what is pressure? an electromagnetic charge can only feel electromagnetic pressure right?
educate! it matters!
I will give you the answer, even if you would rather chase rainbows.
bucking coils, Chris's Partnered Output Coils, when they oppose, they pump current, its a simple charge pump. voltage is gained by dB / dt, or dI / dt, if B or I is not changing, then no more V can be gained. current is pumped from the copper atoms outer orbital electrons when it is put under pressure.
charge moves when exposed to one or more magnetic fields.
electrons change their state when they are stressed, elevating themselves to higher orbital the more they are stressed.
the higher the frequency, the more skin effect. the charge travels down the wire in a helical motion, and is greatest closer to the surface of the wire.
the current is composed to negative and positive charges, unlike normal current only having negative charge.
but those chasing rainbows cant learn such things because they are busy looking for magic.
simple logic, use it or not! educate, it matters! what I have said is all learned from very simple cheap experiment, mostly from Chris's website.
kolbacict
Toolofcortex
QuoteRodin coils takes longer than this to make are you kidding?
nothing happens.the coil behaves like a normal inductance.probably the wrong geometry.
Anti.Semitic
Quote from: kolbacict on February 12, 2020, 04:20:53 AM
I would have to say, not thread or topic related? seems to be an off topic Rodin coil? but ten out of ten for effort!
I have no idea what Rodin was trying to achieve or show other than vortex math concepts?
