0 Members and 60 Guests are viewing this topic.
EMJunkie
@TinselKoala,
Quote from: TinselKoala on February 04, 2015, 02:04:04 AM
I will believe that your current trace is being misinterpreted by you as indicating 10 times more current than is actually flowing in the circuit.
Maybe you should re-do your figures! Even so, if my Current Attenuation Setting was wrong then I still get more output than you my friend!
What are you, still around 80%  :)
A.King.21 will very soon have more than you have also! Like many of the guys over at OUR Forum!
Maybe you should stop, and start thinking how this works?
synchro1
Apparently Woopyjump tried to loop the "Toroid Generator": Here's his account:
Also, he has 4 Tip 41c transistors in parallel and a 1K resistor on the base.
"Hi Gyula
i tried to hook a NOKIA  handphone charger without standard transformer but i could get about nothing. The voltmeter indicated 6.07 volt, than i conected a 10 000 uf 100 volt cap and the charging was a bad dizzling noise and i had to constantly regulate the voltage input to increase the voltage in the cap, Than when the cap was at 6.07 volts the dizzling noise stop and the scope shows a normal fonction ( as per no cap charging)
than i conected a lamp (rated 4 volt DC ) accross the cap and i got a short and brillant ligthing.
So i think that this phone charger (nokia ) is not able to do what i am looking for  8) 8) 8) or any idea ?
but just for fun".
EMJunkie
Quote from: picowatt on February 04, 2015, 02:15:28 AM
EMJ,
Regarding the 'scope shots you posted at OUR, is the channel 1 waveform the drive signal to the primary or the signal measured at your 10R load resistor (i.e., is channel 1 indicating the primary input or secondary output signal)?
Similarly, is channel 2 (the current probe) measuring the input current (primary side) or the 10R load current (secondary side)?
ADDED:
I know you stated that these scope shots were from your secondary's output driving 10R, but you also stated you made these tests some time ago.  Is it possible you have your files/tests mixed up?
There is a significant amount of DC offset indicated in both waveforms that is difficult to reconcile with a transformer output.
PW
Picowatt - all traces are Output Voltage and Current - none are of the input Values!
There is more than something to this! Look for Effects!
You should come to OUR Forum and we can chat more!
Once you see my circuit you will see why DC offset exists, but this does not increase input!
I am finding it hard to decipher those waveforms.  When you present data like this it should be accompanied by your schematic and show where your probes are connected.  You should also show the input waveforms.  You have to show your output power calculation.  Does that scope have a math trace or did you export data to a spreadsheet?
EMJunkie
Quote from: MileHigh on February 04, 2015, 05:36:07 AM
Hmmm, MileHigh - What if I told you that no OU Exists! Would you believe me now I have shown you such wave forms? A Circuit has been presented, I have presented it in my pdf right from the start!
http://www.overunityresearch.com/index.php?topic=2760.msg45434#msg45434
I very much wish people here and elsewhere would pay attention, NOT to OU Claims but Experiments being presented! Thus the Name of the Thread! "Partnered Output Coils - Free Energy NOT "OU CLAIM!!!"
I wish I never mentioned it in my document! People are so greedy, selfish, all they can see is themselves! What they can get for nothing! Lets demand it, and expect it!
Not work for it like I have!
All is now very quiet now I have published the wave forms! even the man himself has gone quiet! Could there be some scrambling going on now to see what people can replicate!
I have made many mistakes along my path, but all I have ever looked for is the Effects! I have published some of them for years. The path starts with looking for Effects! Not measurements!
