0 Members and 45 Guests are viewing this topic.
Toolofcortex
The "node" point, that I refer to, is simply the 0 current kirchoff node.
Aka the antinode.. Pick your configuration, pick your poison.
The peak wave amplitude collision zone, where theres plenty of it, and its all easy pickings low hanging fruits.
All bets are off when it comes to this zone, it was going to be destroyed anyways, or so they say...
All input must be scooped up. The only "price" is the cost of the intense bucking field.
Then the never ending chain starts.
Toolofcortex
Take double wire, wind it in a coil, have it go through the bucking coils middle then curl up in the bucking plane of the middle.
Ground both side of a wire, the positive termination is a plate, open ot short.
The ground reference should be stable along the transmission line, but e field reduced in middle node manoeuver.
The same wire will be wound in 2 coils basically, the top and bottom of the bucking array.
All wire come through and form a circular network of equal antennas, and support the collecting toroid.
Pulse this Array of like 30 wires or so with 100 volt DC, adjust node location perfectly for each strand, then adjust signal.
Time the bucking pulse.
ramset
Hmm..Didn't they give you new Crayons at Above unity ?? atleast the LOUD fisherman makes personally autographed napkin drawings... maybe he could lend you some napkins and a pencil...he is a "nice" man.
actually if you could combine his drawing skills with your writing....
??might actually get some experiments for builders ??
Thanks Grandma
Toolofcortex
Sorry this design too dangerous for you, wouldnt want the CIA to get to  you now if you mess with my designs.
FriskyFritz
Quote from: Toolofcortex on February 17, 2020, 05:19:41 PM
Toolofcortex, you have won the Idiot der Klasse award! Herzliche Glückwünsche!
Fritz
