0 Members and 95 Guests are viewing this topic.
forest
In Mr Preva experiment what kind of input current is used ? Pulsed DC or AC ? If AC then how did you get so much current at high frequency AC ?
kolbacict
I used a regular sound amplifier. It works up to 30kHz. 50 watt.But the OU did not happend ... :'(
AlienGrey
30 khz thats a bit low I used a 1mm wire from some some flat twin and earth to wind the fe toroid and used a CD4047 so as to get 50/50 with p and n bipolar Fet driver
just put the 3 windings on th same toroid two cw and the other ccw worked for me.
I think i got mine to light a car tail lamp at about 1.5 mhz but Tinsel K didnt get res till much higher in freq.
But you could use a fequency gen at 50 50 square wave and drive it into a mosfet driver then a mos fet but the bigger the of set between windings the higher the frequency.
just experiment good luck
AG
forest
If you can make it easy to replicate for anyone  then we could focus on most important questions.
I see two statements : one is using AC with sound amplifier and second is using DC, what is the correct way ?You see, we must answer , what is the connection between turns,turns ratio , input voltage, frequency and so on on then output currents. I imagine it would be then possible to get two bucking currents for example two 2.5A in opposite directions and get net zero from the source. Actually that would be overunity.
How about : Two bucking coils of the same number of turns with only a slight difference of length ?
AlienGrey
Chris Sykes will be on in a while ask him he might have tried that and have some video he can show you I think it might be his tread.
