0 Members and 83 Guests are viewing this topic.
WhatIsIt
Chris is pointing to third field on his own way.
I see nothing wrong with that.
EMJunkie
Quote from: partzman on March 11, 2020, 02:01:38 PM
Chris,
Any coil interactions can be simulated in LtSpice unless there is an outside energy source that has not been accounted for.  It all boils down to accurate models so, if you will document the inductance of each of your three coils along with their dc resistance plus, provide the info to allow the computation of all K factors or coupling factors.  This will require 3 K factors to create the proper matrix and this is done on your end in the following manner.
Label your coils as L1, L2, and L3.  Then measure the inductance L1 aid L2 and L1 buck L2.  Likewise do this with the pair L1 and L3 and pair L2 and L3.  From these measurements, the K factors can be calculated.  Label L1-L3 as to which is primary, etc, and be sure to identify which pair includes the load.
Also, is the core gapped?  IOW, is it operating in a linear mode through the peak current excursions.  Non-linear core operation can be modeled but the complexity is much greater.
Also, what is the estimated resistance of your heated lamp load and power supply voltage used.  I already realize you are using an "H" bridge for the switching.
From this info, a reasonably accurate simulation should be possible with waveforms that would agree with your scope shots.
From my bench tests of your device, it is my opinion that the long discharge time in the output current waveform is from stored energy in the leakage inductance but with simulation we would know for sure.
Regards,
Pm
Partzman, I went back and saw your post, it was not there this morning when I posted... Apologies I nearly missed it.
Welcome back to this thread.
When I introduced Partnered Output Coils, I indicated the addition of another Source of Energy, so this is a yes to your Question. We both know M.M.F is directly related to Energy. My Machine has three M.M.F's. Primary, Secondary and Tertiary Coils. The Sign of the M.M.F is important, as indicated in the Image below, POCOne must Oppose POCTwo, POCTwo assists the Primary.
You will note: P + S + T = T.
The two Partnered Output Coils must Oppose each other, buck.
Regarding the Gap, the machines behave differently, the Core can make all the difference! Sometimes a Gap is required, sometimes not. The best explanations I have found for this is the Residual B Field, Raselli1 explained in his videos. You know this already, so this is for other readers.
You with any other engineers know the simple Ohms Law equations: I = V / R, so getting the Voltage up is of importance, but not going stupid so we blow our lab to hell and back! Safety is the number one concern here!
You may disagree, but my work has taught me we have Electromagnetic Induction only partly right, Voltage is the Change in Magnetic Flux, Current is the Opposition of Fluxes, I believe my experiment proves this. We need to extend Electromagnetic Induction some before we can predict these machines.
I am happy to work with you on a simulation if you wish.  You know as well as I do these machines work! For all readers, if the SIM does not Sim, then it is no proof! It just means the Sim does not allow for the required parameters.
You may remember me stating Loose Coupling is required? We both know Energy comes from the Changing Magnetic Field and the Asymmetry of the Actions.
The Sawtooth waveform is significant and others need to aim for and improve on this concept, it is Asymmetrical Regauging, and when achieved correctly can led to much greater Energy Out than In!
Best wishes,
   Chris Sykes
EMJunkie
@All Readers,
I do not wish to argue or debate simple Science. Nor have manly competitions to see who thinks they may know more or less. All this is pointless drivel!
I wish to point out something very plain and very simple:
Quote from: Floyd Sweet link=http://www.hyiq.org/Downloads/Nothing%20is%20Something.pdf
The source of energy is unlimited, the virtual vacuum of space itself structured by a motional electromagnetic field is the powerhouse.
Whats required? Very plain and very Simple!
A Moving Electromagnetic Field!
Lets not over complicate, when there is no need. Lets learn from the most simple fundamental Science concepts and move forward with them. The Conventional Transformer has a Symmetrical M.M.F Exchange, we need not build the Transformer that way, we can build an Asymmetrical Transformer, where the Third M.M.F is simply the Reaction of the Secondary M.M.F which would normally be directed back on the Primary.
@WhatIsIt - We define Magnetic Resonance as 180 Degree Currents, equal and opposite. You can observe this in The Mr Preva Experiment where Current can be Amplified.
Best wishes,
   Chris Sykes
We know that we need an input to get an output  !
The problem,at first : the input/output ratio
Second : the demand  ! ≤ or ≥ controle ~ UPS emergency technology
It is not the asymetry the problem,but it is the problem that the asymetry is not fix/stable but dynamic/variable in our force/energy/power using world  !
We have different conditions :
appliances in stand-by
appliances in inertia phase
appliances with no load
appliances with low load
appliances with halve load
appliances with full load
these in seriell and/or parallel use and connection
Some only in use for minutes,other used for hours  !
Some with 10W consume,some up to 1500 W nominal consume with 3000 W and more Winrush !
Behind an off-grid "Smart/autonomous grid" is logic  and circuit controle architecture  ! dynamics
Caution : Earl Koenig " Mirror Image Symetry in coil winding" !
Studying the details right !                 Application and Advantage !
There is no energetic "less"  consume advantage,in this case !
EMJunkie
Quote from: lancaIV on March 14, 2020, 06:45:10 AM
Hi lancaIV - Many examples exist!
I have listed what I think are the best here: http://www.hyiq.org//Reference/
Every few years we have someone rediscover the obvious and they soon disappear. Akula, or Roman Karnaukhov was an example some 8 years ago now.
I have been been contacted by Steho Energy, and offered jobs with several Energy Companies:
I have declined in all instances. Unlike other Gagged Inventors, I choose to be Free!
Best wishes
   Chris
