0 Members and 54 Guests are viewing this topic.
EMJunkie
Quote from: dgerlach on March 16, 2020, 05:04:14 PM
Hi Everyone! I'm working on a free energy machine similar to the bucking coil configuration presented in the first post. I'm looking to hire a collaborator / fabricator in the SF Bay Area in California. See below. Hope it's ok to post this here. Thanks and blessings, Derek
We are looking for a practical-minded technician or junior engineer skilled in FDM 3D Printing and CNC Machining. This is a good opportunity for a student or recent grad.
You will work directly with an Stanford PhD in Electrical Engineering with a deep background in exotic technologies.
It is also a plus if you have any skills in: mechanical or electrical design, prototyping, metal casting, exotic technologies including resonant systems, etheric engineering, shape power.
Equally important is that you believe in and are passionate about helping humanity and the Earth reach a higher level via breakthrough exotic technologies.
Your Qualities:
1. Completely trustworthy
2. Expansive thinking not limited by mainstream beliefs
3. Resourceful and quick learner
4. Refined craftsmanship
5. Fluid brainstorming and collaboration
Work is flexible/part-time, in the range of 5-10 hours/week, with pay depending on experience. Most of your work can be done remotely.
We have facilities in both Southern SF and Marin. Big + if you are in/near Marin or SF, or willing to visit at least ~once a week. If this sounds like a match, send Dr Derek Gerlach a cover letter + resume (or examples of your own projects) to dgerlach@gmail.com
Un-believeable!
WhatIsIt
This looks like confirmation that bucking coils are real deal!
And good job opportunity, plus NDA stuff and everything that follows.
EMJunkie
Quote from: WhatIsIt on March 17, 2020, 03:48:22 AM
Yes, Bucking Coils, Partnered Output Coils are the real deal, I assure you of that!
Partnered Output Coil's CAN produce well Above-Unity Results. They can produce Below-Unity results also, it takes some work to achieve Above-Unity. As the IPhone has evolved, the same is true of Partnered Output Coils. You must evolve them, bring about maximum Electromagnetic Field Pumping for Maximum Energy "Generation".
Use what I call the Black Box Syndrome, work back, you require Voltage and Current, so what must your Black Box achieve for Voltage and Current?
Charge has a Magnetic moment, meaning it can be moved by an External Electromagnetic Field! Pumped!
Move forward from there, Pump Charge from the Atom's in the Wire!
Best wishes,
   Chris Sykes
ramset
Authur Ashe... a tennis Player....[maybe Tool was right about tennis players ?
https://www.brainyquote.com/authors/arthur-ashe-quotes
just a note to Chris , still discussing a build with experimenters... times are a bit ruff ...HOWEVER seems spare time may be available in the near future.
Hope all is well with you and yours in OZ.
respectfully Chet K
Thanks Grandma
EMJunkie
Quote from: ramset on March 19, 2020, 09:37:46 PM
respectfully Chet K
Ramset, I must ask, why such a big change in attitude and approach? You know this makes me suspicious!
We both know the history of this thread!
End days prophecy are right now upon us, it is truly up to each and every human being what the future brings. Either we make it, or we do not!
I want humanity to become great, reach for the stars and be who we were supposed to be, Free and Independent, evolved, become Ambassadors of Planet Earth.
Quote from: tinman on June 20, 2015, 06:15:34 AM
So here is where im at with V3 of the rotary transformer. Adding the bucking coil setup did indeed increase the overall output of the system-both mechanical and electrical. When i say bucking coil,i mean a coil that acts as a magnet that can be switched on and off at the right time. As it is a coil that is being shorted,and thus becomes an electromagnet that pushes against the rotors collapsing field just at the right time. This field also travels around the stator core,and boost the field within the secondary(generating)coil that provides the power for the globe.
So we do have a coil that is bucking both against the rotor's field and also the field of the generating coil.
EDIT by Chris:
https://www.youtube.com/watch?v=sDFvKJCW9WI
https://www.youtube.com/watch?v=vMXaA0zlb-M
https://www.youtube.com/watch?v=pioohhRyfHk
Quote from: tinman on June 22, 2015, 06:48:14 AM
They also dismiss EMJ's shorted coil theory,and although he hasnt shown a working device yet,and he messed up the scope measurements,his theory is sound.
Quote from: tinman on September 16, 2015, 12:05:20 AM
Many here laugh at, and mok EMJ, but the fact is , he is basically right in what he is trying to put forward.
No one was ever able to find fault with the measurements Brad did. The Arrows in my work are exactly as Brads machine works. No matter how one chooses to argue, the machine operation is the same, Three Coils, Three Magnetic Fields Two Output Coils, both opposing, as I have indicated. So, some choose to argue the point, I dont care, I say instead of nit picking, learn!
Best wishes,
   Chris Sykes
Quote from: tinman on June 25, 2015, 08:25:39 AM
What-you mean like the below scope shot's?
First scope shot before the diode.
Second scope shot after the diode,and large cap removed.
