Mr.Sykes, Good Mornng !
A question : "pressure",kinetical and/or electro-mechanical or chemical,which conventional units to apply ?
"POWER FACTOR",positive and negative,lagging and leading ,has which functional effect as applied P or S or Q kind and art of"power" and with which displacement result when cos phi =0  ?
Transformer,dc-dc/ac-ac converter or inverter,under no load condition o with " low up to full looad" ?
Sinus,Cosinus,Tangens and Symmetrie-axis of electrical geometrics : you know about it,or not ?
Sincerely
OCWL
EMJunkie
Quote from: lancaIV on April 14, 2020, 03:55:12 AM
"POWER FACTOR",positive and negative,lagging and leading ,has which functional effect as applied P or S or Q kind and art of"power" and with which isplacement result when cos phi =0  ?
Sincerely
OCWL
Good Morning lancaIV,
Power Factor is: 1, we see real power! The Output can be very much more than 90% of the Cycle, and its all Real, Hard Core, In Phase, True Power!
Recently, we have seen one experiment that has given me reason to believe this can change and Output Circuitry may be required. I have not see this, not to this degree anyway. All my experiments have seen 1 pf.
We only need a small  < 10% Duty Cycle Input.
Best wishes,
   Chris Sykes
So very the "duty cycle" and make a diagram(m)!
True power/apparent power / fictious power
It is about "power factor cycle" in a net-grid connection as source-load partnership and "power factor cycle" ina semi-/autonomous with source-load partnership !
EMJunkie
Quote from: lancaIV on April 14, 2020, 04:03:30 AM
Frequency and Duty Cycle play a role, yes, there is a tuning that can make for better results. Is this what you mean?
Rectifying the Output, measuring DC, of course the Current and Voltage are in Phase, PF  = 1.
Worth reviewing the Videos lancaIV:
Quote from: tinman on June 20, 2015, 06:15:34 AM
So here is where im at with V3 of the rotary transformer. Adding the bucking coil setup did indeed increase the overall output of the system-both mechanical and electrical. When i say bucking coil,i mean a coil that acts as a magnet that can be switched on and off at the right time. As it is a coil that is being shorted,and thus becomes an electromagnet that pushes against the rotors collapsing field just at the right time. This field also travels around the stator core,and boost the field within the secondary(generating)coil that provides the power for the globe.
So we do have a coil that is bucking both against the rotor's field and also the field of the generating coil.
https://www.youtube.com/watch?v=sDFvKJCW9WI
https://www.youtube.com/watch?v=vMXaA0zlb-M
https://www.youtube.com/watch?v=pioohhRyfHk
Do the Study, review the History, go back and read the posts! Nothing factious about it! Note the Fan on vs the Fan off!
Best wishes,
   Chris Sykes
2 coils as "random operator" and third coil as " random access":
variator function,the third,like the transmission-/automatic hand gear/lever
#8818 : tinmans videos + power factor definition( wikipedia or other literaric sources) + common physics and chemistry background teach knowledge and Professor Phillip Kanarev "Pulse Power measurement" showment
and examples !
Look for the several different parameters in a " duty cycle" and think about the " internal system" in an "UNRUH"  ,the base for the later " quartz watch" ,introduced to market in the 70',last century,red digits !
From analogous the beginning from our " digital era"!
