0 Members and 99 Guests are viewing this topic.
MarkE
Quote from: EMJunkie on February 04, 2015, 06:13:49 PM
MileHigh,
Well, what I can show, and have already proven, is that the way "You" are being taught to measure things does not account for the real information in the Circuits right in front of you!
Hey ION,
Yes, understand what youre saying. But the scope sees this voltage spike in the secondary Circuit! Just moving the Scope Ground cable shouldn't remove these Spikes. The Scope sees them there initially.
Does this make sense?
We are still missing something here, we are missing 1.3 Watts from the Input Power Source, to the Output, this cant currently be accounted for!
I see the removal of important Wave data on the output, and a loss of 1.3 Watts, there is issues that are not currently explained.
Just moving the Scope Ground cable from 0 Voltage Terminal to the other side of the Load Resistor, should only give us the difference we see in the Load! Not 1.3Watts missing from the equation! This is as the Scientists say, the Values should not change depending on weather you're standing up or sitting down! We are missing Power! Missing real, measured Power.
So Maybe the Cat in Jail, and the nice little Poem is a little too premature MileHigh. Maybe it may end up being you with Egg on your face!
Lets try to work this out, not squabble about this!
You have already said that you do not care about measurements.  The measurement set-up that you have diagrammed is deplorable.  It is very easy to generate completely bogus measurements in switching circuits.  Rosemary Ainslie did so for years despite the patient guidance of skilled people like Poynt99 and (eventually not so patient but highly competent) TK.
EMJunkie
Quote from: PIH123 on February 04, 2015, 07:03:49 PM
In order for me to proceed to answer, I need a little input 1st.
1. What is the exact circuit under test ?
2. What are the component manufacturers and part numbers used ?
3. Where you sourced them would be useful but not required.
4. What equipment did you use to test ?
5. What settings on that equipment ?
6. Where was that equipment connected to the circuit.
Without AT LEAST that info, I would be wasting my time replicating.
There are others who are in progress with less than a month in this. (unfortunately, due to lack of up front info, most are guessing).
You had 16 years.
Why not just spill the beans.
Your 9 out of 10 failures must have told you what not to do, and assuming you documented those failures,
just dig out that info and divulge.
I have wasted no ones time, they have voluntarily attempted this.
I have raised Valid Points and questions!
If we can get to OU then maybe we must understand these Questions before we proceed!
See Itsu's YT Channel: https://www.youtube.com/watch?v=4EbNr3czXdQ&feature=youtu.be
Simply changing the Scope Ground Clamp from the 0 Voltage Terminal to the other side of the resistor gives a huge difference.
EMJunkie
Quote from: MarkE on February 04, 2015, 07:22:39 PM
But MarkE, PPL like you Pushed So I gave you the Curliest one I could! I hope you can help us sort this out!
MarkE
Quote from: EMJunkie on February 04, 2015, 07:36:16 PM
You can move your ground clips and probes all around the circuit and you will get different readings:  So what?  The only measurements that are worthwhile are those that reliably determine input and output power.  You have not set-up to do that.  You have not even established a means by which to measure what you claim to have, much less validate your prior specific performance claims.  The whole thing is a big joke.
PIH123
I am not concerned too much with other peoples time. I care about mine.
Conversing on a forum is not an issue, so I can keep on going till I get what I need to start.
A minimum of 1,2,4,5 and 6 above.
Again, not really interested in your questions.
It is the 1.7 COP claim we are looking at.
In fact anything above 1.0 would be great.
If you had that from the beginning, then it is not you who should be asking questions.
You clearly stated you were here to teach, so go ahead. Answer something, anything.
If we can get to OU, then I would gladly fly anywhere in the world to help investigate why.
You claim to have got there already, why must others also understand why first ?
I am not interested in Itsu's replications. Up until yesterday, you were asking him to change things around (CW vs CCW).
So obviously, he went into this without sufficient info.
He may not yet have all he needs.
