the Ferrocell
Started by pinestone, January 21, 2015, 11:29:39 AM
sadang
Yes, you are right. I found the discussion about the CRTs and I'll continue there. I'll continue writing here about the ferrocell experiments.
TheoriaApophasis
Quote from: TinselKoala on January 31, 2015, 01:12:57 PM
So the ferrocell itself isn't separating white light into its components, but rather reflecting the light from the individually colored LEDs that are in spatially separate locations.
The MAGNETISM is separating the LED light into its components, as tested over and over and over.
likewise the explanation for same is simplex.
Since you forget, white light LEDs contain R , G, and B diodes.   ;D  (duhh).
higher capacitance EM frequencies are drawn to the inertial plane of the magnet, for obvious reasons.
TheoriaApophasis
Quote from: sadang on February 01, 2015, 04:14:14 AM
make them to obey the same angle along one single colored line, but don't explain why they reflect only one color!
Its not reflected because the GREENS and PURPLES are directed along the inertia plane of the magnet
You can always tell where the middle of any magnet under Timms ferrocell because the purples vanish there due to higher dielectric capacitance of that range of EM light frequency.
Youll notice the LOWER power RED light is BRIGHT along the MIDDLE of the magnet, ....whereas the higher frequency light is ABSENT  ;D
TheoriaApophasis
Quote from: pinestone on February 03, 2015, 01:32:36 PM
Bright, diffused light will show the entire field as a sphere.
Check out this video i just made  ( i made one like it months ago actually also, but anyway,.......)
https://www.youtube.com/watch?v=07v_dcg14j0
The magnetic "circle", or the "spirograph pattern" DRAWN OUT ,  100% identical to the hypotrochoid of magnetism under you ferrocell
irrefutable  ;) ;)
By drawing it out SLOWLY, its easy for everyone to SEE   "ohhhhhh, thats it!!!"
How many LEDs of each color are around the ferrocell?
