Wheel vs. lever...
Started by iacob alex, September 24, 2006, 08:49:34 PM
iacob alex
  Hi !
  Rising butt hinges are used to aid doors to SELF close ...due to gravity..
  Rising butt hinges ...if used in a "upside down" doors position aid them to SELF open...due to gravity,also.
  Rising hinges cause the door to rise around 10,5 mm over 180 degrees.
  We can use rising hinges for a wheel concept ( see Maillardet's wheel with masselottes ).
  We can test the lever concept ...if we add a rising hinge (only one !)...so , playing a lever with a single variable arm.
       Al_ex
norman6538
I have have 3 embodiments of the Mallardet concept. Two arms and one wheel. And only one arm performs well - rotates 270 degrees. The geometry is a little different but I have added my own mass shifter that gravity sets and starts the rotation and gravity resets back to balanced.
In the unbalanced mode it acts like a pendulum that self resets at about 160 degrees.
As you know pendulums do not rotate 270 degrees.
I learned 20 years ago when I have something working "freeze it" as is and make another one. So today my goal is to get the 2nd arm working well so I understand what makes it perform well.
I have replicated the 270 degree rotation successfully. And expect to get it on YT tomorrow.
It starts horizontal with a leaning stick holding it steady and ready to start when the camera is ready. Then I kick the stick out so no one can accuse me of adding to the rotation. Then gravity shifts the weight and it rotates past 6, 9, 11 up to noon.
and then comes down and rocks like a pendulum.
So were did that 90+ degrees of rotation come from.
It may have some Skinner effect as seen here
https://youtu.be/rxIRaJlTD4Y?t=9
Norman
kolbacict
Quote from: norman6538 on November 07, 2023, 06:11:22 AM
No. I had also something ten years ago. I do not return this something,because I am afraid that it will be simple reason for my misconceptions. A simple reason why it could work without breaking the laws of physics.  I want to believe in a dream. At least it was honest.
norman6538
thx4
