Motor/Motor Self Runner... A Hoax!
Started by Just..Sayin.., January 23, 2015, 08:00:02 AM
Just..Sayin..
Quote from: MarkE on January 23, 2015, 09:27:43 AM
MH is probably referring to the blur that occurs at 1:31.  The device is a pair of induction motors.  All that is required is an oscillating magnetic field of sufficient strength through the laminations.  Such a field could easily be supplied by a device not visible on camera.
You could be right, and we will probably soon see. It is very easy to replicate this so some one who has the motors will be able to expose it as a fraud quite quickly. A foot pedal from a sowing machine would probably be required to sync the movement of the hands with the spinning up of the rotor.
FatBird
@ Just..Sayin...    Hey Fatbird thought you might like to know that I have spent quite a bit of time talking to Gerard Morin,
                            he is for real. Definitive proof is coming in the very near future, along with a surprise!
I recognized that Mr Morin has O-U as soon as I saw his video.  You & he should both be commended in your
efforts to share this information with the world.
Thanks again.
Just..Sayin..
Quote from: FatBird on January 23, 2015, 09:44:06 AM
Thanks again.
Thanks Bird.... It is quite a story how Gerard came up with the idea to utilize pole transformers.
dieter
Remake of a very old indian fake.
That you didn't know it doesn't make you look very experienced.
I can smell a fake even by the way the camera is held and the scene is lit...
Please try not to waste our time, by doing deeper research before posting. No offence tho, we are all learning.
BR
mscoffman
The easiest way to do this would be to cut the coils in half with a hacksaw or
demrel tool. Then cut away the iron support armature and insert a battery
powered circuit inside the coil forms. Glue the coil forms together again
and wind several layers of new wire. The light would be self powered the
same way. An easy proof would be to stop the motor with the bulb still
attached to the circuit - I'll bet it would still light.
This is fake!    Why not get interested in something that really works?
The Gerard Morin thing is somewhat different, I would like to know if this
works with recently manufactured pole pig transformers, with their oil bath
filled with new silicon oil. Recently manufactured high efficiency transformers
lets say of 75Kvar and 35Kvar at 14.4KVac are significantly physically smaller
than the surplus ones he shows. Is the overunity energy from inside or
outside these transformers? The efficiency of the line transformers are
mandated by standards. For manufacture y2016 these transformers must
be 96% efficient. This may be a reasonable high power gain unit for only
like total $2000 USD.
:S:MarkSCoffman
