2nd law violation:new battery type "poor man's Karpen"
Started by jonfrommanahawkin1, January 29, 2015, 02:14:56 PM
jonfrommanahawkin1
Ok trolls, and the other fine people of this forum I've now gotten ahold of ever one I needed to
The electrolyte is borax in solution of tap water (room temperature)
Borax will dissolve into water per liter till saturated so if you continue to add borax till the water will no longer except any more borax, your mixture is right
I'll do a video on it at some point in the future
But the thing to remember is that not even metal will react the same so you can also use lye which will give you higher current but lower voltage
But you can't use lye and aluminum for obvious reasons that's why I say it's "two dissimilar metals in a non-reactive electrolyte"
I'll help anyone as best as I can to build the unit in the video but I will be making a much larger unit to actually do some usable work
My final design will be carbon and mg to have the cheapest cost but the best potential output
Also to i should point out the original Karpen was .5 v and almost no micro amps and this design does just better then that but the energy will alway be there.
Think in terms of a car battery sized unit to run a light bulb but the physics say it's the same as the original.
And finally I probably won't get a patient because it probably will be considered the same by patent law
All the best
jon
P.s. try and be kind, I've worked very hard at this and I'm not asking directly for anything
pomodoro
 Profitis waits patiently in the shadows of the jungle, ready to unleash his fury... Awfully quiet there old man...
jonfrommanahawkin1
pomodoro
Quote from: jonfrommanahawkin1 on January 31, 2015, 03:31:44 AM
I just got done talking with him
And he did not think that it's a Voltaic Pile with Mg instead of Zn?
Pirate88179
Quote from: jonfrommanahawkin1 on January 31, 2015, 03:26:27 AM
All the best
jon
Well, using carbon and magnesium electrodes in my earth battery, I can fully charge a 650 F 2.7 volt boostcap. (See my Youtube videos)  I can run an electric motor (Bedini) 400 leds, or light a 48" floro tube.  (with the aid of a JT circuit)
No electrolyte except the earth.  This all was a result of the research we did in the Nathan Stubblefield topic here on this site.
I do agree that magnesium and carbon are the easiest to obtain that offer the best differential on the galvanic scale.  However...I got much better results than that by inserting the electrodes into the earth.
