crystal radio: the first real free energy device
Started by franco malgarini, February 16, 2015, 04:52:26 AM
pomodoro
Quote from: profitis on March 13, 2015, 12:48:31 AM
Pomodoro:'I know Moreland is a fake, that's all I've achieved.'
Or you're doing it wrong.or he didn't give all the info.
Possible, but reading his application further, he is practically describes everything that Moray achieved, including the fat sparks at the antenna. He seems to have regurgitated everything that Moray wrote. I think he built up his status in the OU community with this patent application, and easily got money back from giving speeches around the place and some adulation , for a while.
Only fusion will give you enough power, but then you have to convert it to elecctrical energy, and the heat will be a problem.  Moreland once again had nothing physical show the world, just ideas that never materialised.
pomodoro
Quote from: pomodoro on March 13, 2015, 02:55:40 AM
Only fission will give you enough power, but then you have to convert it to elecctrical energy, and the heat will be a problem.  Moreland once again had nothing physical show the world, just ideas that never materialised.
telecom
Quote from: profitis on March 13, 2015, 12:45:47 AM
Telecom:'.Each alpha particle has tremendous energy.'
Yes but the total of natural uranium  alpha decays energy/second is minuscule.unless he stimulated more decay/second somehow
I can easily get hot stone which gives 250000 hits per second. But during the ionization it works as an
avalanche, each hit is making millions of ions.
telecom
Quote from: pomodoro on March 13, 2015, 12:26:18 AM
Well looks like I can't convince you. Changing the topic to real negative resistance, I would have needed the radiation to supply a current in phase with the voltage across the LC tank circuit. This current, being in phase and changing in intensity with the tank voltage would have supplied some current to the load, relieving some load off the tank. With less current flowing out of the tank, its loaded Q would have increased and so would its RF voltage . Already, we saw that the power out of the uranium is miniscule and we also required this power to behave as a negative resistance. I guess I expected the impossible, but I'm still glad I tried.  I know Moreland is a fake, that's all I've achieved.
You already have all of it in that youtube video, you just need to apply antenna voltage to the grid of wires,
like in a triode.You should look for the increased current, not the voltage.If you look at the video,
you can see how many sparks the radioactivity can produce - this is proportional to the energy.
pomodoro
Houston we have another problem! Unfortunately, the triode only works under vacuum. You can not modulate a grid in air. The best you can achieve is a thrysistor action. Off or all On. Please dude, try the video experiment for yourself, im sure eBay has some cheap equipment. You will see that all the current is from the power supply. You owe it to yourself.
