LCAP Free Energy
Started by TheGeneralHackr, February 21, 2015, 05:19:07 PM
John.K1
Just messing with some Brovin,Jt or what ever you name it. My set-up on the picture below. Funny thing is I have to use two independent grounds to get it oscillate. My battery is old recharchable battery, 1.25V in.
The scope across the electrolytic cap  shows 3.3Vrms with some 120mVpp noise. It nicely charge the cap up to 32V if not shorted with the diode . My question is: why two independent grounds needed here?
Cheers
Edit1: there is posibility to use one ground with the diode to the other ground terminal- in this case I am getting on my scope still the same DC line with many negative peaks.
TheGeneralHackr
Its Finally Here!!: http://youtu.be/P2njR2v87TA
The coil in the video is the same one used by Lidmotor to build penny. You can get them at most dollar stores.
The replication actually seems to work better then the original in that it charges the secondary battery much faster!
Pirate88179
Quote from: TheGeneralHackr on May 15, 2015, 12:48:07 PM
Yes, but please notice that Lidmotor (Rusty) does not claim overunity nor even close to 100% efficiency.  He knows his way around these types of circuits.  Nothing wrong with testing them...I do it...a lot of folks do it...just please be careful with making claims about performance that can not be backed up.  Can you light 400 leds from a "dead" AA battery?  I did a few years ago (see my videos) and it is not overunity.
I apologize if I sound harsh.  It is just that guys here on this site have been experimenting with Joule Thief circuits for years and have done some amazing things with them...none of them overunity nor even close to 100% efficiency.  I think that 85% is about the best so far.
Someone here can correct me on this if I am wrong.
TheGeneralHackr
I HAVE SOME UPDATES
The lcap has now been replicated with the exact coil and some improvements have been made to the overall circuit, now it will be much easier to self start.
Some changes with version 2
Instead of using a electrolitic cap I am now using a 0.47 uf tantilium cap instead, connected to that in parallel is a 105Mohm pot.
On the load side of the transistor there is a bridge rectifier leading back into the primary 1.5v battery.
The transistor has been changed from a 2N2222A to a MPS2222A.
Here is the new schematic. I hope it is now easier to replicate!
(If you cannot find a coil that works try the twist tie coil from dollar stores they work quiet nice)
I will be posting a follow up video shortly on advances in the circuit
MarkE
Quote from: TheGeneralHackr on July 25, 2015, 09:16:33 PM
I HAVE SOME UPDATES
This circuit is pretty inefficient because of the diode drops in the full wave bridge.
