Skycollection's "Pentafilar Pancake" inductively coupled "Overunity Potential".
Started by synchro1, February 24, 2015, 04:12:38 PM
Quote from: skycollection on March 27, 2015, 06:22:13 PM
Thanks syncro, i think I have many enemies as zerofossilfuel, and other people that are jealous of my work for me is only fun ..! this motor believe or not.... is a great motor 100% efficient...! if you don“t like the circuit first do it and second comment....!
Jorge:
If you want to be more scientific then your words have to have real meaning.  What does "is a great motor 100% efficient" really mean?
Efficiency in percentage means:  (A/B x 100)
What is A?  What is B?   If you don't define what A and B are, and how you measured them, then your statement is meaningless.
Arthurs:
QuoteI follow your experiment replication, Using normal coil, and Unifilar pancake coil, Bifilar pancake coils, Were carried out comparing drivers to pick up and power
Concluded that:
Whether Unifilar pancake coils, Or Bifilar pancake coils, Their effects and normal coil identical, Without the slightest increase efficiency and improve.
Driving efficiency and normal coil performance is identical;
Lenz resistance and normal coil performance is identical;
Generation efficiency and normal coil performance are identical.
Good work, your results are 100% as expected.  In fact, even before you did those experiments, you can examine the expected results "on paper."  You research how magnetic fields work, you research how a single loop of wire generates a magnetic field, and you can arrive at the conclusion that all of your tests should give you the same results before you even do the experiment.
People that research this stuff have to work on understanding the underlying principles behind what is taking place in their experiments.
skycollection
Is correct, efficience in a motor is A and B, and is a long trip to get 100% but i think Arthurs motor will do it...! The process of the pancake coil is not difficult, i did my first pancake coil in 10 minutes with my acrylic mold, and the idea of the plastic resin to protect the pancake coil is very good idea also, this coil is for many years...! THE POLYMIDE INSULATING IS A GOOD IDEA ALSO, but this material will not change nothing, the pancake coil is good with this film and without the material, i will work soon in a new pancake coil "INSIDE OF A PERMANENT MAGNET" ....VERY SOON....!
Quote from: skycollection on March 29, 2015, 11:35:05 PM
A and B could be anything that you want them to be.  But if you don't define them, then any efficiency number means nothing.
No motor will ever have 100% efficiency, but like I state above, you must define what efficiency you are talking about.
Why would you want to put a coil inside of a permanent magnet?  What is the reason for this?   What are you expecting to happen?
