Skycollection's "Pentafilar Pancake" inductively coupled "Overunity Potential".
Started by synchro1, February 24, 2015, 04:12:38 PM
Arthurs
Hi skycollection
Please confirm that my copy is correct?
If there are errors,Please help me correct it.If it is correct,I can compare normal coil and pancake coil test shooting video.
But the best you can also make a normal coil,Comparison test with pancake coil,This is the most convincing.
For your experiment some suggestions:
1) For your current experiment,Experimental meaning little battery charge,To the battery charge time,There is a phenomenon:Observed on the surface charge quickly,Voltage rises quickly,There are actually "false charge"Seem charging is completed,But access to a certain load,Soon the battery will discharge end.In other words:Essentially no real complete charging.
2) When the LED is used as a load,Be sure to use both current and voltage meter to monitor the load,Because now the LED manufacturing process is very good,High brightness LED surface observation time,The actual current is very small.I actually tested a 12V / 3W LED lights,When the input voltage is 10V,Visually observed brightness is already high,At a time when the current is only 50mA,That is the power consumption of only 0.5W.When the voltage is increased to 12V,Current will soar,At this current will reach 300mA.
3) Use the "AA" batteries as a power source,Be sure to use the instrument to monitor the input voltage and current,Although "AA" batteries,But it is still able to provide a current of about 500mA-1A,Only its discharge time is relatively shortened."AA" batteries not a symbol of the power of the weak.
Look forward to your experiment to achieve better results!
skycollection
OK No. 1 is correct, when i am charging a battery it seems that is complete the charge, but when i connect a load, discharge very fast...! charge is not complete.
No. 2 is correct, led lights consume a very small voltage and the brightnees is almost complete with very low voltage.
No. 3 i don´t know what is the question, if you can more specific or change the question, remember that i don´t speak english.
skycollection
Arthur, you have a great error in how to assemble the pancake coils......YOU HAVE TO START AGAIN....! I SEND YOU A DIAGRAM AND SORRY FOR THAT...!
skycollection
Arthur, if you want i can send you my "original" pancake coils by DHL EXPRESS two days, i have many pancake coils that you can prove in your laboratory, but i need the shipping cost and some money for me for my work, if you are interested contat me to: skycollection@hotmail.com
Quote from: skycollection on March 29, 2015, 11:35:05 PM
Is correct, efficience in a motor is A and B, and is a long trip to get 100% but i think Arthurs motor will do it...! The process of the pancake coil is not difficult, i did my first pancake coil in 10 minutes with my acrylic mold, and the idea of the plastic resin to protect the pancake coil is very good idea also, this coil is for many years...! THE POLYMIDE INSULATING IS A GOOD IDEA ALSO, but this material will not change nothing, the pancake coil is good with this film and without the material, i will work soon in a new pancake coil "INSIDE OF A PERMANENT MAGNET" ....VERY SOON....!
Jorge:
There is no logical or rational reason at all to put a coil inside of a permanent magnet.  Coils only respond to AC excitation and a fixed and non-moving magnet produces a DC magnetic field that will have no affect at all on the coil.
You have seen many diagrams of complex magnetic circuits that consist or one or more coils, some ferrite core material, and one or more permanent magnets to create some sort of transformer circuit.  The designer of the circuit will say something like adding the magnets to the circuit are for "more power" or something like that.  It is all lies, all bullshit and ignorance.  A permanent magnet will have zero affect on some kind of AC magnetic circuit.   Also, in many cases you can assume that eventually the permanent magnets will eventually become demagnetized because of the AC excitation from the coils that are being driven in the circuit.
I will repeat:  Using magnets in some kind of coil or transformer circuit is 100% nonsense that will have no beneficial effect.  You see it all the time, and all the time it is nonsense.
