Skycollection's "Pentafilar Pancake" inductively coupled "Overunity Potential".
Started by synchro1, February 24, 2015, 04:12:38 PM
synchro1
Quote from: Arthurs on March 29, 2015, 10:37:06 AM
Hi Skycollection
I follow your experiment replication, Using normal coil, and Unifilar pancake coil, Bifilar pancake coils, Were carried out comparing drivers to pick up and power
Concluded that:
Whether Unifilar pancake coils, Or Bifilar pancake coils, Their effects and normal coil identical, Without the slightest increase efficiency and improve.
Driving efficiency and normal coil performance is identical;
Lenz resistance and normal coil performance is identical;
Generation efficiency and normal coil performance are identical.
May have offended you, but you can also use the normal coil for comparison.
This result is erroneous!
TinselKoala clearly demonstrates that the "Tesla Pancake Coil" transmits power more efficiently than the "Unifilar Pancake Coil" in this video:
https://www.youtube.com/watch?v=mvb39SwTXBE
skycollection
And the problem is that Arthur did not replicate correctly my pancake coils, i am agreed with you, i have many years studying the pancake coils and i prefere the pancake coil instead of conventional coil, with the pancake coil i can induce the voltage to the other pancake coils very easy (inductive coupling effect) the pancake coils enter in "self oscillation very easy, and the pancake coils have unknown effects and undiscovered effects...!
synchro1
Let's say for the sake of argument that the "Tesla Bifilar Pancake Coil" has the same power as the "Unifilar Pancake Coil". Two "Unifilar Pancake Coils" will still form a less efficient "Inductive Coupling" then two "Bifilar Pancake Coils". Where's the harm in using the "Bifilar Pancake Coil" if everything else is even except for the singular advantage under discussion?
hoptoad
Quote from: MileHigh on April 01, 2015, 10:07:31 AM
When a coil is being driven at it's self-resonant frequency, the AC impedance is zero.  However, the resistance of the wire is real and it is always there.  That resistance will always oppose the flow of current.
I agree, but I don't recall seeing 'self resonance' of the coil thrown in as part of Synchro's statement. My error perhaps, however...
At self resonance the SUM of AC reactance is Zero. That does not mean there is no inductive reactance in the coil. It means the capacitive and inductive reactance are equal and therefore sum to zero, leaving only the coil resistance as both the real and effective impedance.
Zero reactive impedance is not the same as Null or None.
synchro1
The unsolved question is whether or not the "Tesla Bifilar Pancake Coil" can supply a rotor pulse and transmit the same pulse simultaneously to an inductively coupled coil in close adjacency that dual purposes the power? The other question is; If doubling the power this way is possible, can we continue to multiply it with additional coils? Skycollection has at least demonstrated the appearance of this infinity reflection of power effect, without producing any real definitive test results.
