Skycollection's "Pentafilar Pancake" inductively coupled "Overunity Potential".
Started by synchro1, February 24, 2015, 04:12:38 PM
hoptoad
Quote from: synchro1 on April 01, 2015, 11:59:09 PM
The unsolved question is whether or not the "Tesla Bifilar Pancake Coil" can supply a rotor pulse and transmit the same pulse simultaneously to an inductively coupled coil in close adjacency that dual purposes the power?
Good question, and one which is worth exploring experimentally. As I understand Tesla's description of his bi-filar pancake coil, the advantage came from its increased inter-winding capacitance, allowing it to store more energy between discharges in his tank experiments. At close parallel proximity, two Tesla Bifilar Pancake Coils may possibly exhibit a very much higher capacitive power coupling rather than a much higher inductive coupling compared to a mono filar pancake.
I don't know and am only speculating this may be the case.
skycollection
I have in process my new PANCAKE COIL (SINGLE WIRE) QUADRIFILAR PANCAKE COIL "INSIDE OF A PERMANENT MAGNET" in other worlds, inside of a permanent magnetic field. This pancake coil is experimental, i don´t know what happen in this pancake coils, and i don´t have plans, i don´t have special reasons to make this experimental coils, this is experimentation only, very soon i will post my first experiment.
synchro1
Two "Bifilar Pancake Coils" might transmit a pulse from one coil to the other at an efficiency close to 100 percent while the magnetic field propels a rotor. That would constitute an overunity effect. Sandwiching a "Bifilar Pancake Coil" primary with two receiver coils, one on each side, should either half or double the transmitted power. These are not really very difficult tests.
Arthurs
Today's test:
Traditional normal coil And pancake coils used to drive (motor) comparison test,Using exactly the same test platform,Pancake coil has been reworked in accordance with the method proposed Skycollection.
Traditional normal coil parameters and pancake coil exactly the same,All use AWG 20,Coil outer diameter 80mm,The inner diameter of 32mm,Traditional ordinary coil 480T.Each Unifilar pancake coil 30T,Bifilar pancake coil 15T,Use 16 pancake coils form a complete coil,Each 8 pancake coils as a group,2 groups form a complete coil,The total number of turns and the traditional normal wound coil unanimous.
Testing purposes:
Traditional normal coil and pancake coil in the same circumstances,Speed ​​and power consumption for driving (motor).
For safety considerations,Test voltage all use 4V,Since the voltage 4V speed has reached the 1000rpm or more.
Image data for the test.
"1/2 Unifilar pancake coil"Using a coil in which the one group,
"Full Unifilar pancake coil"Using a coil in which the two groups(Series).
In the process of testing,Constantly adjusting the rotor coil distance,Until maximum speed.
Test Results:
At present, yet not observed pancake coil has advantages.
Pancake coil generating tests conducted later.
synchro1
@Arthurs,
Two inductively coupled "Bifilar Pancake Coils", two capacitors, two diodes, a flop switch, a battery, a DMM and a magnet rotor are all it would take to determine conclusively if there is any genuine "Skycollection" overunity effect.
The first test would involve measuring the percentage of power transmitted between the two "Bifilar Pancake Coils" to the receiving capacitor from a solitary pulse through inductance alone, then comparing that to the percentage transmitted again with the magnet rotor in place.
I believe that gain is possible from feedback due to any magnet rotor motion. The magnet rotor needs a diametric or N-S polarity. This is a simple test with possible dramatic and far reaching consequences.
The diodes would have to be positioned to allow for only one way power transmission to the secondary capacitor alone. Any measurable gain to the receiving capacitor over the transmitted induction percentage from rotor motion would qualify as OU output.
