Magnetic Engine Video
Started by vineet_kiran, March 07, 2015, 07:57:05 AM
vineet_kiran
Quote from: MarkE on March 24, 2015, 02:33:47 PM
You perform work moving your "shield".
The nerves in your hands should be telling you that it is harder to move your "shield" back and forth when there is a stack of magnets on one side of the ball than a similar sized block of unmagnetized metal.
My nerves are not telling me anything and if you try it your  nerves also will not tell   anything because you are not removing the shield out of the pole.  I am moving the shield within the surface of the pole without subjecting it to change in flux concentration.
vineet_kiran
Quote from: Low-Q on March 24, 2015, 05:18:06 PM
Here is a video. Simple experiment showing that iron will be "hard" to pull away from the field between two opposing magnets.
This will take energy by the same amount as the gain in the pendulum magnet. However, I did not make the pendulum magnet, just two opposing magnets I try to remove the shield away from.
http://youtu.be/bcQfMGakGQc
Vidar Sir,
You are trying too hard to disprove my expreiment but out of the way!
Several times I have mentioned that you have to use a lengthy magnet having poles on faces and whether ball or shield has to move in a parallel plane on the lenghty magnet within the pole so that it will not be subjected to change in flux concentration.
If you try to move the steel or ball away from the pole of magnet it will naturally experience dragging force towards pole because pole will have maximum flux concentration.  What is strange in that?
After confirming the experiment only I have posted the experiment and you can see from the video that it is working fine. if not
I would not have posted that experiment or myself would have told that it will not work.
I don't have any idea of misguiding or giving wrong information.
My request is please try the experiment as it is and if possible use a thicker shield.  You will get amazing results.
Wish you good luck!
Pirate88179
Quote from: Low-Q on March 24, 2015, 06:01:43 PM
I can try. I have most of the hardware and tools to make one - just for educational purpose. The video above is highly simplyfied.
Vidar
Vidar:
For God's sake, please be careful...we all saw what happened to your garage when you experimented with the famous "Lead Out" unbalanced wheel theory.  I doubt that your insurance company will cover any additional damage..ha ha.
MarkE
Quote from: vineet_kiran on March 24, 2015, 08:31:55 PM
If the flux did not redistribute therefore changing its concentration then there would be no effect on the pendulum.  Would you like to try a different tall tale?
vineet_kiran
Quote from: MarkE on March 24, 2015, 11:23:04 PM
Flux get redistributed with respect to the pendulum not with respect to the shield (or it will not have effect on the shield) because shield is moving in parallel plane on a lengthy magnet with all its points equi-distant from the pole.
There is lot of difference between rowing a boat on water and pushing the boat deep down into water.
Why don't you understand?
