Magnetic Engine Video
Started by vineet_kiran, March 07, 2015, 07:57:05 AM
MarkE
Quote from: vineet_kiran on March 24, 2015, 11:45:27 PM
Flux get redistributed with respect to the pendulum not with respect to the shield (or it will not have effect on the shield) because shield is moving in parallel plane on a lengthy magnet with all its points equi-distant from the pole.
There is lot of difference between rowing a boat on water and pushing the boat deep down into water.
Why don't you understand?
No matter how long you make the magnet, the magnetic lines are not orthogonal especially close to one of the poles.  The flux through the shield varies with position and work is therefore exchanged changing its position.
Low-Q
It is YOU that don't understand, or don't want to understand.
The shield have deep influence on the magnetic flux - how the flux orient itself in precense of the shield. The shield is magnetic.
If the shield was very very long and you shielded with the center of it, it would not have much influence on the force needed to move the shield back and forth becaus the flux density woult literally be the same on each side of the shields center.
However, as soon the end of the shield approach the magnet, the flux behaviour start to change as you continue to move the shield. Energy must be spent to remove the shield completely.
I will make a video showing this so there will be no doubt what's going on.
Vidar
MarkE
Unless Vineet is the victim of some terrible condition that has cost him all the feeling in his hand, he knows that he is exchanging work when he moves the shield.
vineet_kiran
Quote from: MarkE on March 25, 2015, 03:15:42 AM
Let Vidar make the video then we will know who has lost his mind due to prejudice.
MarkE
Quote from: vineet_kiran on March 25, 2015, 03:47:30 AM
It is simple physics which Low-Q (Vidar) has already demonstrated in a video.
