Thanks to ALL for your help!!
Rewriting the history of the symbol of shamash
Started by gravityblock, March 21, 2015, 09:51:10 AM
Pirate88179
Quote from: joel321 on March 26, 2015, 03:19:38 AM
Not to mentioned a perfect circle. And also the suns plasma going over it like a cloud of smoke. Right after it took off, there where three "tornado" tethers that could be seen. And also how the sun plasma cloud just move out of the way like smoke. This was a UFO seen by millions of eyes (well maybe just hundreds of people that viewed that lol) and it is still a UFO to this day. :)
The object was stationary! Ice debris that goes around the sun never melts and never stops! lol Sometimes I feel that NASA thinks that everyone is stupid and no one can understand what we are actually looking at with our very own eyes. lol
I have never seen a ice debri just be a circle and then stop with there with a tornado tether and then just does a 90* take off = geometrical. Even in small scale experiments, that cannot be done by ice not even an RC airplane.
PS, I saw a documentary by a scientist guy doing a through out dissecting of that pulsating picture evidence you posted...I forgot his name but he did all the math and lots more. I'll try to find the video of that.....and post his name. He can be viewed on youtube but I forgot his name.
EDIT: Here is his video and name, look at his study and theory.
https://youtu.be/tnFp7OZmBkQ?t=20m55s
https://www.youtube.com/watch?v=2bWWx-zqoTg&feature=youtu.be&t=31m30s
https://www.youtube.com/watch?v=2bWWx-zqoTg&feature=youtu.be&t=13m19s
NASA uses JB Weld and what you see is the sun reflecting off of the chips of the JB Weld which was used in the construction.
(Just kidding)
gravityblock
Joe Parr Pyramid Research (rotating pyramid induces an orb around it and levitates)!
The Power Of A Pyramid!
Pyramid with 50 degree angles with 4 sides creating enormous amount of EMFS on the meter.
This machine is very primitive. It's a wooden box containing three devices. There are two four-sided 5in. squared base pyramids that are 5in. high (see photo #3). The third device is a sphere which is 5in. in diameter (see photo #4). All three devices are made of solid iron and collectively weigh 40lbs. (see photo #5). The box is constructed of solid wood and fastened with wooden pegs and glue (see photo #6). It is 3in. thick on all sides and weighs 60 lbs. Extended from the box are four iron terminals.
The three devices are installed in the box (see photo #7). The box serves as a frame supporting the three devices in a fixed "bow-tie" configuration. On either side of the iron sphere, the points of the iron pyramids are as close to the sphere as possible without touching (see photo #8).
To operate the machine, orient the box in a north/south direction (see photo #9 and the last video). The box is then raised at least 3ft. high or insulated from the earth. Both pyramid terminals are connected to iron cables that extend 50ft. long, laying on the ground. An iron cable buried 8ft. into the ground connects the terminal at the bottom of the sphere to the earth. The terminal at the top of the sphere connects to an iron rod that is mounted on a wooden handle, to insulate the operator (see photo #11 and the last image). Finally, secure the cover to the box (see photo #10).
Gravock
gravityblock
Quote from: gravityblock on March 29, 2015, 05:41:36 AM
A triangle (pyramid) inside an orb (sun) as we see depicted on the ancient artifact and the image of the sun by Nasa.  Looks like a star-gate or portal!
NASA discovers hidden portals between the earth and the sun (video)!
Gravock
