Tong wheel and coils
Started by nathanj99, March 22, 2015, 06:22:26 PM
nathanj99
Hi
Does anyone know where i can find more info on the Tong wheel? I am looking at building a 60cm wheel with 16 magnets on it. And then 16 coils around the outside of the wheel, but I have no idea what size wire to use for the coils, how many turns etc etc. would anyone be able to offer any advice?
Thank you
burnit0017
https://www.youtube.com/watch?v=aaF1_AyZe-c
Hi, I fabricated a pulse motor. It has two magnets on the rotor,one electromagnet and a repulsion magnet 180 degrees on the stator. It only operates with a heavy flywheel mounted on the rotor. I used 22 AWG with 250 turns measuring 2.4 ohms for the electromagnet. @ 12 volts the amp meter reads 0.3 amps and runs at 200 RPM. There better designs. Small wire more turns equals more power but has higher resistance, so there are trade offs. I hope this helps. I look forward toward your results.
Paul-R
nathanj99
Quote from: burnit0017 on March 22, 2015, 06:45:39 PM
Do you have a pickup coil on that?
nathanj99
Quote from: Paul-R on March 23, 2015, 12:13:00 PM
Try Patrick's book:
http://www.free-energy-info.com/Chapter2.pdf
Thanks Paul. Yes this is where I got the idea. However there is no real info on the coils. I was seeing if anyone had any experience before I go and spend a large amount of money making 16 coils.
Nath
